got small rear case, need mounting ideas for OEM rear rack - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 10Likes
post #1 of 16 Old 05-27-2019, 07:28 AM Thread Starter
I got a Pelican Vault 200 handgun case that i want to mount to my OEM reAR RACK [2019 wEE] i was thinking of looping U bolts through the rack and drilling the boc and putting nuts inside. any other easier ways?
vboost is offline
post #2 of 16 Old 05-27-2019, 07:44 AM
Motor7's Avatar
I positioned mine where I wanted it, marked it, then drilled holes in the oem rack. I used 4 SS bolts with fender washers and Nylock bolts to secure it. I highly recommend Nylocks due to the constant vibration.
notacop, cyclopathic and vboost like this.
'15 DL650XT
Motor7 is offline
post #3 of 16 Old 05-27-2019, 08:16 AM Thread Starter
this seems much easier than me trying to fit U bolts through the holes in the racks. thanks
vboost is offline
post #4 of 16 Old 05-27-2019, 10:31 AM
U bolts require a bit more precision. I drilled holes and used a piece of flat stock from the hardware store under the rack.
bobbyvstrom and vboost like this.
post #5 of 16 Old 05-27-2019, 11:25 AM
I did mine like Motor7 but i also put nylon bushings over the bolts so they couldn't shift in the rack. It doesn't scratch the rack that way. I've got the same box and I like it a lot.
NVDucati and vboost like this.
Dubldee17 is offline
post #6 of 16 Old 05-27-2019, 11:44 AM
NVDucati's Avatar
You can consider some neoprene washers between the rack and box for waterproofing and anti-vibration.
vboost likes this.
Member: AMA
NVDucati is offline
post #7 of 16 Old 05-30-2019, 10:42 PM
Would you mind posting a few pictures of that? Sounds like a perfect setup, but I can't quite envision it. Also, hello from Knoxville!
koretex is offline
post #8 of 16 Old 05-31-2019, 11:56 AM
Anthony_L's Avatar
Drilled and tapped 3 spots on my rack. Bolt/waher in and only worry about them working loose on long trips (periodic check at gas up time).
Anthony_L is offline
post #9 of 16 Old 05-31-2019, 01:41 PM
Motor7's Avatar
Yes I can since I am 22 days into a new knee and all I can do is stare at my bike. Stand-by for pic's..........
'15 DL650XT
Motor7 is offline
post #10 of 16 Old 05-31-2019, 02:55 PM
Motor7's Avatar
Ok, I lied...it was my '07 that I drilled the oem rack on, my '15 came with a aftermarket rack installed. Anyway, here are the pic's, the install on the oem is just a little more involved due to space limitations. You can however mark the box location, then take off the oem rack and drill it. It will take a little time, but way easier to access for nuts n bolts.
The box:
position relative to rear seat:
inside the box fender washers:
'15 DL650XT
Motor7 is offline
Question On Givi Monokey Top Case Mounting keuka DL650A - 2012-2016 3 02-28-2014 10:22 PM
Top case mounting plate for OEM grab bar tomcat688 DL650 and DL650A - 2004 to 2011 10 05-25-2013 06:23 PM
DIY Quick Release Mounting for Trunk Case? Casper137 General V-Strom Discussion 4 03-29-2013 06:55 PM
