Biker with Ear Problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 22Likes
post #1 of 43 Old 05-26-2019, 11:19 PM Thread Starter
Hi!
I really love to ride bikes but the problem is I have sensitive ears that are prone to tinnitus. Just bought a pair of noise reduction ear plugs/ear piece and they do not fit well in my ears. I'm planning to get new ones but I'm torn between these two brands: Big Ear Inc. and PinLock.
First one is a company that offers customized ear protection and the second one had good reviews online. The thing is...I think I have an uneven ear canal and I'm not sure if a pair of generic plugs would be very useful. I just hope you can help me decide what to buy.
P.S. I'm open to all your suggestions.
Thanks!
NoobBiker101 is offline
post #2 of 43 Old 05-27-2019, 06:34 AM
PerazziMx14's Avatar
My suggestion would be pay a visit to the local audiologist to see what they can do to help with your situation. Most likely they will custom it you with ear plugs. And who know if you have insurance it might cover or at least partially cover the cost??
Also if you settle on disposable ear plugs, dispose of them at least daily. Disposable ear plugs are just that. Do not reuse them day after day.
If you get custom or reusable ear plugs at the end of each day they need to washed with a mild soap and then dried before putting back in a sealed case.
With disposable or reusable the idea of either using new or washing is to cut down on bacteria that you are shoving into your ear canal. So many times I see guys take ear plugs out of their ears then straight into a sealed container and into he nice dark warm tank bag for biological experiment to grow. Then when the reinstall the ear plugs they give them a good lick to lube them up. Now you have a combo of freshly blossomed ear canal bacteria with a application of Miracle Grow (bacteria laden saliva) to jam into a mice dark, warm and moist ear canal that acts like a Petri dish.
I also suggest you regularly wash any ear plug case or use fresh zip top bags everyday to house them when not in use.
A few seconds per day for proper ear plug maintenance can make all the difference in having or not having a nasty ear infection.
This go for the earbud wearing public as well. At the end of the day you really should clean them with a some sort of antibacterial wipe to keep germs at bay.
PerazziMx14 is offline
post #3 of 43 Old 05-27-2019, 07:39 AM
Motor7's Avatar
You might try the Big Ears, but for custom molded those are quite expensivebeing North of $100.
I have tinnitus too(power tools, firearms and motorcycles have taken their toll) and when working on the range used custom molded plugs. It's been years and I can't remember the company name but they still live in my range bag.
What I have found is that the disposable type are just about as good as the custom jobs. Many times on the indoor range at work we had to double up, custom in first, then ear muff type over that. Outdoors the custom were sufficient.
Google "custom molded ear plugs" and you will find several in the $25-50 range.....i would experiment with the cheaper style first to see if they suit you.
The most comfortable ones are going to be the ones you wear regardless of price.
Even though it is not recommended for tinnitus sufferers, I wear a Bluetooth headset with the foam type earbuds(not the rubber ones). I listen to a lot of music when riding, but do keep the sound level low. Over the years I have not noticed the tinnitus getting worse and still have my symphony of Cicadas singing in my head every day all day....good thing I like the song of the Cicada
Coach23101 and RestoRider2017 like this.
'15 DL650XT
Motor7 is offline
post #4 of 43 Old 05-27-2019, 08:01 AM
Also Ran's Avatar
I have bad Tinnitus and have yet to find ear plugs that provide much help. A good wind screen and disposables are the best for me so far. Good luck and let me know what works for you.
"There's a Grey blur and a Green blur. I try to stay on the grey one." Joey Dunlop
Also Ran is offline
post #5 of 43 Old 05-27-2019, 08:56 AM
Very similar here; I've had severe tinnitus for 40yrs; guns, power tools, loud amps.
I've learned to live with it, wife got me to go to an audiologist 30 yrs ago, and about every 10 yrs, and nothing's to be done.
My ears ring with earplugs anyway. Earplugs only keep out ambient noise so the ringing is more "upfront" and clear!!
But in ear bluetooth headsets work fine, although louder is better.
I recently purchased Cardo Packtalk Bold, am tweaking that in my Sedici helmut.
Hang in there, you'll find what works for you!
Makonasson is offline
post #6 of 43 Old 05-27-2019, 09:59 AM
I've got a set of Big Ears and another brand I forget. The forget reaches deeper into the ear canal and is comfortable and actually easier to install than the Big E.
It also does not come out of the ear as far as the Big E. So it's comfortable for using when sleeping in a mob area, like camping with snorers.
The Big E is a stubby arrangement. Both work equally well when finally inserted. Gotta use a lube or give yourself a Wet Willy to insert them into the ear canal. Gotta wet the ear and glob some spit on the plug too. They insert with a rotating motion.
They can fall out of the ear and go dancing across the ground when you take off the helmet too. Especially the Big E.
I paid less that $100 for either pair but if you want other than the basic plug it will go up in price. Like having it work with Blue Tooth.
Your local audiologist will charge maybe 2-3 time as much. I was appalled at what they quoted for my wife's hearing aid adapter.
I got mine at BMW rallies from a wandering Ear Plug guy. If someone has a shop in town, the cost may be higher.
Just checked. There are scads of Big E dealers around the country. The basic Ear plug is $85.
post #7 of 43 Old 05-27-2019, 02:03 PM
Syb
Syb's Avatar
I made my own earplugs from EasyMold, a silicone product from Michael's craft store. You mix the two types of silicone together, knead it very well, ball it up and gently push it into your ears making sure to get it enough into the canal. Leave it there for a while (I forget how long, it's in the directions) and then you've got "custom" ear plugs. I put a little smear of vasoline on them and they work well. If you screw up, you can try probably 30 times for under $25. I got this trick from RCinNC (I think that's their user name here).
Sent from my SM-G955U using Tapatalk
notacop and tucsonray like this.
Enjoy the ride
Syb is offline
post #8 of 43 Old 05-27-2019, 02:18 PM
RestoRider2017's Avatar
Location: Apopka Florida NW of Orlando near a twist in the road and a hill on the horizon...
Lots of great tips on the ear plugs - Very good to know. I too have suffered from ringing in the ears. Years of commercial
construction work, Carpentry, Loud engines, Loud bikes, You know the drill - Loud music too. All have the big bugs singing in my head
too. I heard that this stuff called Lipoflavinoid was supposed to help with this, Have any of you tried this ?
I also wear a disposible 32 DB noise reduction foam ear plug. They were like $12 for 50 pairs. they work real good and keep the road noise
to an extreme minimum, wind noise too .
2017 DL 650 , Shad 23 bags, Givi crash bars, 32 watt LED aux lights , Goldwing pegs, Metalic silver front fender, Lazer cut aluminum Chain guard, Madstad 20" windshield
light smoke tint , Blu/blk Driven Racing Billet bar ends, Dbl Take adventure mirrors , BeadRider Ceramic bead seat cover,
Stock exhaust for now. Yoshimura 3/4 system simmering on low in the oven.
Avatar image is a custom made Harley Sportster all hand built from junk parts from a retired engineers desk. Took 80 hours to make.
RestoRider2017 is offline
post #9 of 43 Old 05-27-2019, 04:22 PM
Macdoc's Avatar
exactly
Canada 2018 CB500x >2009 CBF1000 sold 10 Wee ABS sold 09 Burgman Exec sold 10 NT700v sold
Australia> 04 KLR650 93 ST1100 sold
Macdoc is offline
post #10 of 43 Old 05-27-2019, 04:24 PM
Big Boy's Avatar
I prefer this type of ear plug.
A small drop of baby oil helps me insert them without any trouble.
W. C. Fields
Big Boy is online now
Tags
accessories , ear plugs , motorcycle , new owner , protection
:( WTF? Fuel Problem? strompilot DL650 and DL650A - 2004 to 2011 6 05-19-2012 01:48 AM
HELP PLEASE !!!!!! this problem is driving me nuts shepski DL650 and DL650A - 2004 to 2011 8 03-27-2012 07:26 PM
OEM Handuard problem gjl DL650 and DL650A - 2004 to 2011 9 02-20-2012 12:27 AM
Givi Crash Bar Installation Problem Mr Weebles General V-Strom Discussion 7 05-17-2009 08:57 PM
Does anyone have this strange problem ? nerol996 V-Strom Service and Maintenance Questions and Discussions 6 08-22-2008 07:58 PM
