Bridgestone BW501 tread depth - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 11 Old 05-01-2019, 11:49 AM Thread Starter
My 2015 DL650 has a Bridgestone BW501 front tire. It looks to be in very good condition but I have no idea how the tread depth compares to new. Can anyone provide a tread depth measurement from the centre of a new BW501 front tire? There's no place locally that I can go to have a look myself.
Thanks!
2015 DL650A, Candy Daring Red (mine)
2017 Honda CB500XA, Candy Rose Red (my wife's)
2015 Honda CBR300R
1982 Suzuki GSX750S Katana
1981 Suzuki GS650GL
1983 Suzuki GS450L
Skinner is offline
post #2 of 11 Old 05-01-2019, 12:00 PM
RCinNC's Avatar
It depends on the tire type, but as per Bridgestone's site, the tread depth when new for a 110/80-19 Type E tire is 6/32". This is the rating you'd find on tires for something like a Super Tenere. For a Type G tire the depth is 8/32", and for a Type J tire, it's 5/32".
Bridgestone Motorcycle Tires
RCinNC is online now
post #3 of 11 Old 05-01-2019, 12:01 PM
K9 Wee's Avatar
002100 110/80R19M/C 19 BW501F BW TL J 59H H 25.9 4.3 5 2.50 536 41 Suzuki DL1000 V-Strom 2014 - 2016
From Bridgestone site....5/32's is stock depth.
Great tires....on my second set on an '09 Wee...typical mileage for me has been 12-14k per set, your mileage may vary!
http://www.bridgestonemotorcycletire...dualsport.aspx
______________________
2009 Orange DL650
SW Motech Rally Crashbars, Skidplate & Centerstand
Givi e22L Sidecases
Shad 33L Topcase
Wolfman 40L Waterproof Duffel
Givi Tanklock 20L Tankbag
Techiwik Long Underwear
1978 Honda CB550K-Sold
K9 Wee is offline
post #4 of 11 Old 05-01-2019, 01:21 PM Thread Starter
Thanks. I wasn't aware of the motorcycle tire specific site, only the general Bridgestone site, which is essentially useless for MC tire specs.
Regarding the various types - what's the difference? The front tire on my bike is a Type G, which is not the original front tire per the PO. It has about .15" to .16" of depth remaining, which is about .10" down from new (.25"). The back tire, which I'm currently replacing, is a BW502 Type E, which also does not seem to be stock. I'm replacing it with a G as it turns out. The only difference I can see from the specs is tread depth.
So, is there much to this? This is the first time I've noticed different "types" of the same tire and same tire size when buying MC tires.
2015 Honda CBR300R
1981 Suzuki GS650GL
1983 Suzuki GS450L
Skinner is offline
post #5 of 11 Old 05-01-2019, 01:33 PM
I believe the 501/502 G spec is suitable for the 650 and the J spec version is suitable for the 1000, the reasoning being that the heavier bike (1000) requires stiffer side wall than the 650. I have no idea why the tread depth would be different on the various specs of the same tire. I have a new G spec 502 on route that will hopefully show up today.
gdrew is offline
post #6 of 11 Old 05-01-2019, 01:41 PM
Motorpsychology's Avatar
@Skinner :
I'd be skeptical about buying a used tire regardless of how it appears or its tread depth. You may luck out and buy a tire from someone who just wanted to get something that matches whatever front they were running, or switch from a street-bias to a more off road capable set of tires, but it may have a misaligned belt causing a squirm or a bead that won't completely seal. I've bought good-appearing truck tires to replace a blowout on a semi while on the road. Invariably, one of the two afore mentioned problems manifest themselves after a time.
18 wheels move the cargo, 4 wheels move the body, 2 wheels move the soul -unknown
“Of all the paths you take in life, make sure a few of them are dirt.” - John Muir
I visited the Air & Space Museum- didn't see a thing...
Motorpsychology is offline
post #7 of 11 Old 05-01-2019, 01:53 PM Thread Starter
Originally Posted by Motorpsychology View Post
@Skinner :
Sorry if I confused anyone - I'm not buying a used tire. I'm replacing the back tire with a new one, and was curious about how much is left on my front tire as compared to new.
Motorpsychology likes this.
2015 Honda CBR300R
1981 Suzuki GS650GL
1983 Suzuki GS450L
Skinner is offline
post #8 of 11 Old 05-01-2019, 02:37 PM
My bad Skinner I misunderinterpolated your post.
post #9 of 11 Old 05-01-2019, 02:54 PM
RCinNC's Avatar
I don't believe those letter ratings like Bridgestone uses are industry standards; I think it's an in-house thing with Bridgestone. It's not a load rating thing (that's a number designation) or a speed rating (that's a letter, like a "V", but it's always attached to the load rating, like "59V").
If I had to guess (and believe me, it's a guess), the differing tread depths have something to do with the altered sidewall sides for each tire type. A radial tire has to maintain a specific ratio of sidewall height to tire width, height, and profile. They may have to decrease the tire height for some versions because of the different sidewall, and decreasing the tire height could also decrease the tread depth.
Or maybe I'm full of shit. Could be a little from column A and a little from column B.....
post #10 of 11 Old 05-01-2019, 07:31 PM
K9 Wee's Avatar
The letter designation from Bridgestone is an OE (Original Equipment) for specific manufacturers. G for BMW, E for Yamaha, J for Suzuki, etc.
There are slight differences in sidewall flex, load rating, etc. between the tires based on manufacturer specs. Any one of those listed should work so long as properly sized.
2009 Orange DL650
Givi e22L Sidecases
Shad 33L Topcase
K9 Wee is offline
tread depth and rain keithert General V-Strom Discussion 4 05-12-2014 11:58 AM
Anakee III Tread Depth YTK DL650 and DL650A - 2004 to 2011 5 04-12-2014 09:01 AM
Tyres for 650 stretch49 Australia-New Zealand 96 03-25-2011 09:40 PM
Tread Depth Of New Trailwings echo DL650 and DL650A - 2004 to 2011 13 06-24-2008 10:32 AM
