Tire changes 2014... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 19Likes
post #1 of 29 Old 04-26-2019, 03:40 AM Thread Starter
So I live in NYC and motorcycle shops want 120 to 200 to install a pair of tires, last year same shop did for 80 now wants 125 for pair or 70 for 1. On general principle can't pay that as I can get a car tire patched for 15 to 20 bucks at a local flat fix shop, tip the guy 10 bucks and he looks at u like jesus.... Basically will end up changing own tires not to have a bloody anus. Question is do I really need to balance a nice set of Michelin tires? Cam I just line up valve with light spot and call it a day?
dakor82 is offline
post #2 of 29 Old 04-26-2019, 04:45 AM
twenty's Avatar
I always just take the wheel in and have them change out the tire and balance. only costs about $30 CAN per wheel. it's the extra labour that's driving up the price.
I'd say that balancing is quite important, you can purchase a unit to do them at home, might pay for itself in time.
twenty is offline
post #3 of 29 Old 04-26-2019, 08:46 AM
locoblanco's Avatar
Some will say it's ok, some will say your bike will explode. Personal experience, I don't balance and haven't noticed any problems.
notacop likes this.
locoblanco is offline
post #4 of 29 Old 04-26-2019, 09:06 AM
I would go ahead and balance the tire as peace of mind.
Motorcycle tire balancers are not very expensive on ebay. pick up some adhesive lead weights while you're at it.
If you have the room in your house. look into a motorcycl tire changer. Like you, I did the math on the cost of mc tire replacement. With just a few tire replacement, you will get your money back. especially when you have dirt bikes.
Check on No-Mar Classic tire changer. I didn't like the bottom tier brand by no-mar. the classic seems like the best for the cost.
2008 Suzuki Vstrom DL650
2013 Yamaha WR250R
2004 BMW R1150RT
2002 Ducati 998 Superbike
2001 BMW R1200C Phoenix/Independent
1982 BMW R100RT
2003 Kawasaki Ninja 250r - Sold
1985 Yamaha FZ-750 - Sold
1984 Kawasaki GPZ-750 - Sold
bmwguy is offline
post #5 of 29 Old 04-26-2019, 09:15 AM
I use Ride-On tire balancer and sealant compound. It coats the inner surface of the tire and eliminates the need for wheel weights.
Bugzy and dust_buster like this.
Hatchi is offline
post #6 of 29 Old 04-26-2019, 09:27 AM
I always run Michelin PR4s (or whatever PR version is current).
I always change and balance myself, just balancing the wheel-tire assembly on its axle, suspended over a couple 5-gallon pails. IMHO, that works surprisingly well, and the price is right.
Balance matters, I think, but just my opinion, and maybe only if a lot of time is going to be spent at 80 MPH+ (indicated). (My bike spends a fair amount of time there).
Even with Michelins, I find wheel-tire assemblies always out of balance. The problem is mostly in the wheel, in my experience (I've played around with balancing the wheel only (no tire), and it takes quite a bit of weight just to balance the wheel). On the plus side, little, if any, extra weight is then required to balance the wheel-tire assemblies.
Believe it or not, I'd noticed that, when I'd turn loose, completely, of the handlebars of my bike, the head would shake some. At that time all wheel weights were on one side of the wheel (yeah, dumb, but I didn't think it would matter, being so close to the centerline of the bike). At next tire change I tried to put the same number of weights on both sides of the wheel. Made a big difference in "head shake" with hands off the bars.
Live and learn...
Bugzy and Motorpsychology like this.
2012 Wee2 Adventure. Black. Bought at 26K miles. Now 45K+. Love it!
HokiesRWee is offline
post #7 of 29 Old 04-26-2019, 09:36 AM
Highwayman2016's Avatar
I have a Michelin PR4 on the front of my 650 and a Road 5 on the rear, yes they need balanced. Good luck finding the light spot, Michelins aren't marked. I do them myself with stick on weights and a Harbor Freight balencer except when a friend offers his machines.
2014 650 Strom
Highwayman2016 is offline
post #8 of 29 Old 04-26-2019, 10:03 AM
I dont see how you can compare patching a car tire to replacing motorcycle tires. And are you talking removing and reinstalling the rims yourself?
You dont NEED to do anything! But why wouldnt you balance? And how does someone else's not balancing affect what you do?
If youre that destitute where an additional $40 would keep you from riding, should you even own a motorcycle in the 1st place?
You dont pay to have them balanced. You pay to know they are in balance. Some tires Ive replaced required no weight to balance, but those were few and far between. I have yet to see a motorcycle or car tire manufacturer state that their tires do not need balancing. Have you?
Why would you cheap out on "a nice set of Michelin tires"?
madscrapper85 likes this.
MAZ4ME is offline
post #9 of 29 Old 04-26-2019, 11:04 AM
Spec's Avatar
Get some tire levers and change your own tires. It's more of a technique thing than a brute force thing!
I used to balance tires and have used Dyna Beads and Ride On. I don't bother anymore just line up the mark on the tire with the valve stem. Highway speeds here are 80+ mph, bike is smooth. My advice is mount the tires and take it for a ride. If vibration is bothering you balance the tires.
HokiesRWee likes this.
Spec is online now
post #10 of 29 Old 04-26-2019, 11:14 AM
blaustrom's Avatar
Well this can become a long debate.
You can balance the tire on the axle with suitable support. I use a couple of car jack stands. Takes a bit of patience but it works.
An interesting exercise is to check the balance of the worn old tire before you remove it. Then decide if balancing is not overrated. As mentioned above, if you find vibrations at certain speeds, you may need to go back and balance the wheels.
DonOhio45813 and dust_buster like this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
THE Tire Thread MightyShep Suspension and Tire Tech 1012 08-17-2019 01:20 AM
Flat tire trip? rpatton General V-Strom Discussion 6 04-01-2014 07:56 PM
My tire tale - new Pirelli Scorpion rear MrNobody Suspension and Tire Tech 7 07-22-2013 03:56 PM
Front tire not holding air? TheWall Suspension and Tire Tech 23 04-16-2013 11:21 AM
