Finally installed 16T sprocket - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 65Likes
post #11 of 97 Old 04-08-2019, 09:27 AM
stevet's Avatar
I had a 16t on my '07 DL650, no problems, I could pass anything and get up to full freeway speed before getting to the bottom of the ramp. With the new '18, and it's slight power improvement, with the 16t I'm going 70mph before I even need to merge into the traffic lane. I'm a bit over 200lb plus full riding gear. The 16t is a benefit on my bike.
Steve.
Webfors likes this.
stevet is offline
post #12 of 97 Old 04-08-2019, 09:33 AM
Originally Posted by Webfors View Post
Engine torque at the crank doesn't change. But wheel torque certainly will. It's all about gearing and the impact on laying power down to the wheel. Here's a good link that shows approximately a loss of 6% power (at the wheel) going to a 16T:
So those that have the 16t have not noticed any perceptible decrease in max acceleration or any negative drive-ability issues?
What about highway passing?
Wheel torque will be less when measured in the same gears through a given rpm range when comparing a 16t to a 15t. But what most cannot comprehend is that you may not always be in the same gear! My 16t will hold 75+ mph with electronic cruise going through the high mountain ranges of New Mexico and Arizona in 6th gear.
Never owned a DL 650 yet that didn't need downshifted 1,2, 3 or more times to pass! That is just how they are.
With the 16t you might find yourself staying in the sweet spot of the torque range longer. The 16t can be one transmission gear lower and turn nearly the same rpms, so who do you think will win that roll-on? Acceleration from a stop is at least as fast, as no one can use full throttle and quick clutch engagement in first gear in most street conditions. After you are moving, the 16t makes each gear seem to fit the bike and the speed you want better than the 15t. You really don't see much difference in 4th and 5th gear just cruising along with the 15t, but the 16t makes each gear fit a speed better.
There is only one negative to the 16t. It does take a bit more throttle/clutch action to get it moving from a dead stop. Not really that much different from other bikes I have owned. Once moving the 16t is better in about every way. The 17t was simply too tall. Noticeably harder to take off, and in 6th gear the engine labored too much to be any real benefit.
Webfors likes this.
realshelby is offline
post #13 of 97 Old 04-08-2019, 09:53 AM
Not to hijack this thread, but a question about the latest Gen DL650 ('17-'19) speedo. Is the speedo read off the transmission gears or off the ABS ring? If ABS ring, front or rear? I did change the sprocket on my '09 Wee and really liked the lower revs when running the freeways, and as noted by others who have re-geared, I didn't miss the tiny bit of acceleration (torque) when riding around town.
badjuju is offline
post #14 of 97 Old 04-08-2019, 02:00 PM Thread Starter
KSM
KSM's Avatar
This. My experience exactly.
Webfors likes this.
2012 DL650A (purchased Dec 2017)
2005 DRZ400S (sold Dec 2017)
1972 Norton Commando (sold 1984)
1978 Suzuki DR370 (sold 1982)
KSM is offline
post #15 of 97 Old 04-08-2019, 04:43 PM
Webfors's Avatar
Right, and I get that. The 16T may make what power is available more useable, negating the power loss as a result of gearing up.
I guess what I'm getting at, is that theoretical max torque/power will be reduced. Meaning, put two of the same bikes, on the same dyno, at the same time, in the same atmospheric conditions, and the 15T will provide higher HP/TQ numbers. Whether that's relevant, except for a very specific point in the torque curve, is what needs to be understood. What I'm hearing is it's not.
I suppose it's one of those things you just need to try.
Numbercruncher likes this.
Two wheels for realz!
Webfors is offline
post #16 of 97 Old 04-08-2019, 04:46 PM
Webfors's Avatar
How many miles do each of you have on the 16T sprocket?
Webfors is offline
post #17 of 97 Old 04-08-2019, 11:21 PM
Highwayman2016's Avatar
Webfors likes this.
2014 650 Strom
Highwayman2016 is offline
post #18 of 97 Old 04-09-2019, 07:49 AM
Can the 16t counter sprocket be run with the same chain or does it require a slightly longer chain? If it makes any difference, I have a 2017 dl650.
For those that have done the change, any specific counter sprocket recommended?
2017 V-Strom 650
2012 DRZ 400
Jhat is offline
post #19 of 97 Old 04-09-2019, 07:57 AM
Dynos don't run through the gears. You put the bike/car into a chosen gear and make the pull. Now a chassis dyno like car manufacturers and bike manufacturers use could/would give torque outputs as you shifted up.
Theoretically you would be able to show more max torque ( we won't use horsepower as it doesn't exist on a dyno! It is calculated from torque readings. ) only because that would occur in first gear. But there is a more important number that many go by. Average torque/horsepower. In that case you probably wouldn't show any real difference overall.
The best example I have is a Mustang I used to drag race. The car would run 11.88 at 113 mph with 3.91 rear gears. We installed 4.56 ratio gears and went to the same track with same conditions. 11.89 was the best time it gave. So, no improvement. One big reason is the extra shift required into 4th gear made up for any advantage in acceleration. Same with the DL 650. You shift more and when you up shift in the 15t bike the 16t bike is still in the lower gear. Meaning it is actually pulling harder than you are at that moment.
We can talk about it on paper. But I have run this setup for many thousands of miles. Much of that side by side with a 2004 DL 650 that kept the 15t. You don't lose ANYTHING from a stop in acceleration! You WILL lose something in a 6th gear roll on compared to an otherwise equal 15t bike. But who rolls on in a DL 650? Downshift several gears and go!
Webfors and Motorpsychology like this.
post #20 of 97 Old 04-09-2019, 08:05 AM
strominateacup's Avatar
[QUOTE=Webfors;5375225]Engine torque at the crank doesn't change. But wheel torque certainly will. It's all about gearing and the impact on laying power down to the wheel. Here's a good link that shows approximately a loss of 6% power (at the wheel) going to a 16T: NO
You're confusing torque and power. With taller gearing, at the same engine rpm and in the same gear, there will be a reduction in torque at the wheel. The power does not change. As others have pointed out, you can hold each gear to higher road speeds, so overall acceleration is the same. Getting off the line might be a little slower with the taller gearing, that's all.
Edit: (I should've read all the posts before replying, other people have said it better than I have!)
There are holes in the sky where the rain gets in,
and the holes are very small, that's why rain is thin.
Spike Milligan.
strominateacup is offline
Bigger sprocket review sanfordnc DL650A - 2012-2016 9 09-07-2015 12:58 AM
Up date on Crankcase catch cans & 17 tooth front sprocket Warlock DL650 and DL650A - 2004 to 2011 9 10-08-2012 02:01 AM
14 tooth front sprocket from SV Racing xjchad Product Reviews 4 08-17-2011 12:31 AM
Front sprocket inspection - NO TOOLS Scott E. Bonds Maintenance, Tech and Products. 3 08-04-2011 06:22 PM
2002 DL1000 Front Sprocket removal chazzei1 DL1000 from 2002-2012 1 05-24-2011 03:50 PM
