Is "Top Tier" gas worth it? - Page 7 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 51Likes
post #61 of 80 Old 04-06-2019, 02:00 PM
Bugzy's Avatar
My bike sat for 6 months over Winter with non ethanol 94octane gas in the tank, and no stebel, and then started on the first push, like it had been ridden every day.
Would it do that with low octane ethanol gas? maybe, but I'm not going to try it.
I find gas mileage goes up with higher quality gas, and I feel better performance as well, so i'm going to stick with it, and only put regular with ethanol in if there is no other convenient option.
Now the difference between regular with ethanol, and high tier gas with ethanol, I doubt that makes as much of a difference, but perhaps a minuscule amount, still, which side of the scale do you feel more comfortable with? The extra costs are not noticeable in the big picture.
Bugzy is offline
post #62 of 80 Old 04-07-2019, 09:14 AM
Originally Posted by realshelby View Post
Some owners manuals will have an addendum about driving in higher altitude areas. Specifically allowing lower octane fuel. Because the air density is much lower, the engines cylinder pressure will be lower. That means you don't need the higher octane fuels to prevent detonation. Common practice in higher elevation areas to have 89 or 90 as the highest octane available. Which works fine, but know that if you fill up there and head toward sea level there is a chance you will notice a bit of pinging. I am always careful about that on the bikes and cars.
Ah, okay. That makes sense then..
Houstrom46* is offline
post #63 of 80 Old 04-07-2019, 02:31 PM
jokermtb's Avatar
Back when I had my old 1984 GPz750 8-valve kawasaki, it actually ran worse on the highest octane fuel. It wasn't a very high compression engine, so the extra octane didn't allow the fuel to combust as quickly as a lower octane fuel would at those lower compressions. Now, if you have a high compression engine, the extra octane will prevent the fuel from combusting too early (which causes pings/detonation)......
So, think carefully about what kind of engine you have, and whether the extra fuel cost is actually doing anything, or in my old kawasaki's case, making things worse (and costing the most!)
For my vstrom 650, it happily burns the 87 octane low end fuel.....doesn't run any better or worse if I happen to fill up with 91 octane.
jokermtb is offline
post #64 of 80 Old 04-09-2019, 08:50 AM
cyclopathic's Avatar
Originally Posted by ERockJL View Post
bear with me here...
Does every top tier fuel station carry top tier rated fuel? If you go to the app, lets say a shell station close to me, it does not have the top tier logo, even though its a top tier rated company. If i go down the road near me a valero station has the logo in the app.
Is this just a formality, and every single mobil, shell, sunoco station carries top tier fuel.
Having TT gas available on every station is required for certification.
cyclopathic is online now
post #65 of 80 Old 04-09-2019, 08:54 AM
Well that solves that, thank you.
2016 DL1000 ABS
ERockJL is online now
post #66 of 80 Old 05-07-2019, 09:31 PM
The high grade fuel is worth it if you like your engine! If you can find it with no ethanol added even better! Ethanol murders carborators so never run that crap in a carbed motor as it eats up gaskets... not sure of the negative effect to fuel injection.
Kreuld is offline
post #67 of 80 Old 05-08-2019, 06:28 AM
twenty's Avatar
modern engines are made with ethanol friendly materials but that doesnt change the fact that corn produces less power and acts like a magnet for water.
I run all my bikes ethonal free as well as anything with a carburetor. here that means the top grade gas only at specific stations. the higher octane rating is only required in engines with a higher compression ratio and does little if anything in engines that dont call for it.
Charlie1982 likes this.
twenty is offline
post #68 of 80 Old 05-08-2019, 07:22 AM
Webfors's Avatar
I can tell/feel/perceive a difference running 87 with ethanol vs 91 without. It could just be in my mind, but I can tell. It would be interesting to have a buddy switch them around on me and see if I can really tell
Two wheelz for realz!
Webfors is offline
post #69 of 80 Old 05-08-2019, 11:58 AM
Highwayman2016's Avatar
I usually use top tier regular in my 650 and can feel no difference when I use premium.
2014 650 Strom
Highwayman2016 is online now
post #70 of 80 Old 05-08-2019, 12:20 PM
drrod's Avatar
I expect, in this day and age of lawyers, that manufacturer's recommendations are what is best for the engine. Exceeding them is fine (although may not be cost effective) but to go under them is at your own peril if/when any warranty issue arises.
There must be a lot of things that go into determining what octane fuel to use. Not just compression ratio. For example:
my CBR1100xx has a CR of 11:1 and Honda calls for 87 octane fuel (regular).
my ST1300 has a CR of 10.8:1 and Honda calls for 91 octane fuel (premium).
my DL650 has a CR of 11.2:1 and Suzuki says 87 octane (regular)
Probably things like configuration, bore/stroke, carbed, injected, etc. all play a role in the final manufacturer recommendation.
Webfors and MrF like this.
drrod is online now
Suspension Upgrade worth while for general commuting? HuntWhenever Suspension and Tire Tech 29 10-27-2016 06:40 AM
MRV's 2014 MERA "5 & Dime" Rally Report MRV Ride Reports (Route Sheets) 5 09-13-2014 10:16 PM
Worth it to buy 2012+ wee 1985usa DL650A - 2012-2016 3 08-02-2013 12:17 PM
How much is it worth? seawolf06 General V-Strom Discussion 3 07-26-2009 03:25 PM
