Auxiliary Light Mounting - Opinions? - Page 5 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 12Likes
post #41 of 44 Old 03-24-2019, 04:56 PM
RestoRider2017's Avatar
Location: Apopka Florida NW of Orlando near a twist in the road and a hill on the horizon...
I do know the lights I purchased from Yitamotor on Ebay had the same lights in spot beam or wide beam.
One set came with the harness and the others did not. I got the ones with the harness which are spot beams.
They are 16 Watts each with 6 LED bulbs per light. I adjusted mine so the beams sit about a foot lower than
my headlight on low beam. This is from a 20 foot distance back from a vertical wall.
The width is right around 4 feet apart at the same distance back.
This aluminates the road well at night and so far no flashing of the high beams from oncoming drivers so I think
I'm not blinding anyone at approach. For $20 total even though they are cheap I think they are just fine
and save my money for other items of noteworthy cause. I'll post back later with any issues that may come up.
But all the other lights I've purchased from this vendor are good to go . www.yitamotor.com
2017 DL 650 , Shad 23 side bags, Givi crash bars, 32 watt LED driving lights ,
Goldwing pegs, silver front fender, Lazer cut aluminum Chain guard, Madstad 20" windshield
light smoke tint , Blu/blk Driven Racing Billet bar ends.
"any comments made on this forum are purely for amusement purposes only.
not to be confused with actual knowledge"
RestoRider2017 is offline
post #42 of 44 Old 03-24-2019, 09:05 PM
I used bicycle reflector mounts that clamped to the 7\8" crash bar worked well
pwkorte is offline
post #43 of 44 Old 03-25-2019, 11:52 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
Unless they are Euro style lens beams, in my experience the beams of all the LEDs I have tested have been spherical and not sensitive to orientation. So for all practical purposes two flood or spot or pencil beams would provide the same shape illumination whether stacked or turned sideways. Euron beams are orientation sensitive.
thirdofthree likes this.
richlandrick is online now
post #44 of 44 Old 03-26-2019, 05:59 PM
That sounds good. All I know is they work just fine and the road ahead is lit up brighter and wider than with
just the headlight. So it is definately an improvement over nothing at all. For $20 I cannot go wrong.
Accessory light mounting bracket BTC V-Strom Modifications and Performance 6 04-24-2014 02:28 PM
Auxiliary Light Install Modog88 General V-Strom Discussion 4 03-21-2013 07:25 AM
Driving/Fog Light Mounting Options Vne V-Strom Modifications and Performance 24 02-07-2008 08:36 AM
