07 V can't find the dealer plug - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Brockie
post #1 of 4 Old 03-16-2019, 06:28 PM Thread Starter
Location: Boise National Forest, Central Idaho Mountains
Howdy V experts..
It's sunny today in the mountains of Idaho (still have several feet of snow on ground), so I decided to resume troubleshooting my 07 V.
Last (late) fall I had a charging issue, so I replaced the stator and did the jb weld fix for 4 floating magnets. Bike would start & run on fresh charged battery prior to replacement, but would not charge.
So I decided to check the error code (never needed to do this since buying bike last summer), but.. I have dug, and dug but cannot find
the dealer mode plug. -- Any ideas?
I suspect the crank position sensor (?)
cavedweller22 is offline
post #2 of 4 Old 03-16-2019, 07:18 PM
Try YouTube--it shows a DL650, I dont know if your 1000 is the same. The videol(link woudnt open on this site) shows it adjacent to the battery on a bracket, white 6-pole connector with a black rubber cap.
MAZ4ME is offline
post #3 of 4 Old 03-16-2019, 07:40 PM
Brockie's Avatar
This link with images shows it. https://advrider.com/f/threads/v-str...r-mode.452388/
Here's an even better thread, with codes. https://www.vstrom.info/Smf/index.php/topic,7061.0.html
D.T. likes this.
Brockie is offline
post #4 of 4 Old 03-16-2019, 08:38 PM Thread Starter
I found the dealer plug
Thank you for the replies...
I finally found the plug.. it was rear of the R/R about 8-9" along the frame tucked up under the wiring harness...
-C-12....
tire patch vs. plug H8-3Putts V-Strom Service and Maintenance Questions and Discussions 28 11-11-2015 12:11 PM
Heated Grips male plug Wazza2773 DL650A - 2012-2016 7 09-05-2014 11:24 AM
12 DL650 Heated Gear Plug Location jurgenk General V-Strom Discussion 5 04-27-2014 12:58 PM
Did dealer screw up my bike? Does your bike backfire? wendortb V-Strom Service and Maintenance Questions and Discussions 6 09-03-2009 05:19 AM
