One Bar gas flashing - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 03-16-2019, 06:15 PM Thread Starter
Hi, my Suzuki boulevard vl800 2012 have a problem on level gauge, I put the switch on, and mark fine, but after I release the stand after 30 seconds approx, the lights bars go to one bar and flashing,I change the cluster and the sender unit, i make jumper on plug of the stand and do the same thing, the stand switch is fine, I make test to the plug on sender unit under the tank and look good. Somebody have any idea how can I fixed. Thank.
MMedina is offline
post #2 of 2 Old 03-16-2019, 07:26 PM
It MAY be different, but I have the '07 VZ800 Suzuki Service manual. It shows resistance settings at each lever sensor height position, and resistors to be used on the sending unit to get the different gauge readings. Have you checked continuity between the cluster and the sending unit?
MAZ4ME is offline
Flashing F1 ToadRide DL1000A - 2014-2016 10 06-08-2017 01:42 PM
Overdrive light flashing in 5th. Rogue Reaper General V-Strom Discussion 12 09-29-2015 08:36 PM
OEM heated grips flashing swisstrom DL650A - 2012-2016 8 06-24-2015 07:37 AM
Hey now I know what the flashing gas symbol is for!! one4adventure DL650A - 2012-2016 38 07-02-2012 05:16 PM
