Mixing oils - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 81Likes
post #21 of 49 Old 02-06-2019, 11:54 AM
If your car or motorcycle was down a quart, would you worry about only topping it up with exactly the same oil as it was originally filled with? Maybe, but most of us would just add a quart of something suitable and call it a day.
Big B, Fox, shu and 3 others like this.
V-Strom Ry 2 is offline
post #22 of 49 Old 02-06-2019, 11:55 AM
drmonbowen's Avatar
Originally Posted by bajakirch View Post
All are motorcycle-safe and are 10W-40.
Do it.
Now I need to add characters...
DesertBike likes this.
drmonbowen is offline
post #23 of 49 Old 02-06-2019, 01:15 PM
what did an injector change have to do with mixing oils?
Motocanada is offline
post #24 of 49 Old 02-06-2019, 02:12 PM
BC Rider's Avatar
Look at it as an opportunity to make your lawn equipment last longer. Splitter started up easy at -10C a few weeks ago on synth.
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #25 of 49 Old 02-06-2019, 03:11 PM
The synthetic will argue with the non synthetic as to who should go through the oil pump first, resulting in an impasse. Oil starvation and seizure will be the result!
Willie is offline
post #26 of 49 Old 02-06-2019, 03:51 PM
dean.peckford's Avatar
It was in reference to the cost of engine repair. What does this post have to do with the original post?
Past Bikes
2017 Suzuki DR650se, 2013 Suzuki DR650se, 2008 Suzuki M50 Boulevard, 1973 Kawasaki 750H2, 1978 Yamaha XS400
dean.peckford is offline
post #27 of 49 Old 02-06-2019, 04:10 PM
Farkle Purchasing System
DesertBike's Avatar
Yep. I have a 20+ year old Ford with very leaky valve covers which are never going to get fixed.
It's pretty much a bi-monthly ritual to add a quart of oil to keep the level up.
While I stick to the same viscosity profile (5W-20), I don't bother to put in the same flavor (High Mileage, part synthetic, whatever) and brand, as it'll just be leaking out eventually anyway.
I still do a full change every 6000 miles or so, but it's mostly to swap out the filter. The actual oil is on a constant rotation, so most of it never gets a chance to break down. :P
DesertBike is online now
post #28 of 49 Old 02-06-2019, 06:43 PM
"Yep. I have a 20+ year old Ford with very leaky valve covers which are never going to get fixed."
Sounds like my 4Runner.....
One nice thing about having a leaky engine is that you don't need oil changes because you are always running fresh oil through the system. Reverting back to the Horseless Carriage era cars and motorcycles that had total loss systems. And like leaky old Brit bikes covered in puked oil, it preserves the the and makes restoration a practice in spraying gunk and hosing it off!
post #29 of 49 Old 02-06-2019, 06:55 PM
OydnaR's Avatar
so, in the end, what is the collective opinion, should I top off my coolant with Dexcool ?
IBA#9560
Copyright (c) 2019
OydnaR is offline
post #30 of 49 Old 02-06-2019, 07:41 PM
Moderating in moderation
Vindex1963's Avatar
I purposely run a mix of Rotella T 15w-40 dino and Rotella T6 5w-40 syn for make my own 50/50 blend.
My testing proves the blend shears less than straight T or straight T6.
MariusD likes this.
2015 Suzuki V-Strom DL650 bought new 4/26/17
2015 Victory Cross Country bought new 7/11/15 (dyno tuned 118hp 116tq)
If it's not broken, make it better
My take on oil: Name brand, wet clutch compatible.....BAM good to go.
Vindex1963 is offline
Mixing trail/road front tire with pure road rear tire bajakirch Suspension and Tire Tech 2 06-26-2018 10:45 AM
Mixing Coolants? Austin Borkenhagen General V-Strom Discussion 11 03-26-2017 04:35 PM
Mixing Tires... Fourvalve General V-Strom Discussion 14 05-23-2009 11:52 AM
Mixing viscosities IronButt Jup General V-Strom Discussion 9 03-04-2009 09:25 AM
