A fine how do you do - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 17Likes
post #1 of 31 Old 01-17-2019, 01:36 PM Thread Starter
larolco's Avatar
Pulling into work this morning after a 45km commute, the bike all of the sudden fell into a left turn funny-like.
At least it happened just as I was arriving and not in the middle of nowhere. That's my first flat in something like 7 or 8 years when I had three in quick succession.
DesertBike likes this.
DRZ400SK17
larolco is offline
post #2 of 31 Old 01-17-2019, 01:38 PM
ptcaflyer's Avatar
Plug it !
joshuahilbig likes this.
'15 DL650A
ptcaflyer is offline
post #3 of 31 Old 01-17-2019, 01:54 PM
STCorndog's Avatar
You're really screwed. I would plug it too. Matter of fact, I am on a plugged rear now, but it slow leaks a little between rides.
STCorndog is offline
post #4 of 31 Old 01-17-2019, 01:59 PM Thread Starter
larolco's Avatar
Originally Posted by ptcaflyer View Post
Plug it !
I did!
Unfortunately the cheapo compressor I carry around has bounced over one too many a washboard road and wouldn't build any pressure.
Fortunately there's a 60 gallon compressor here at work so I didn't have to resort to using a CO2 cartridge.
Seems to be holding air so far...
DRZ400SK17
larolco is offline
post #5 of 31 Old 01-17-2019, 02:04 PM Thread Starter
larolco's Avatar
Funny, you know? Every flat I've had has been a Phillips head screw.
I've used rope plugs on all of them. Sometimes they leak down a little but no biggee.
DRZ400SK17
larolco is offline
post #6 of 31 Old 01-17-2019, 02:04 PM
Plug it !
Plug it! Then put a patch on the inside, I had a couple on plugs blow out over the years. You may have no trouble with the plug however it pays to play it safe..
Norm
Riding for 60 years
Current Rides
2018 Suzuki DL 1000 ADV.
2010 Yamaha XT250
2005 BMW R 1200 RT Gone
2011 Suzuki DL650 Gone
Plus 43 other Dirt and Street Bikes from AJS to Harley in my past...
Old Codger is offline
post #7 of 31 Old 01-17-2019, 02:25 PM
I swear I have not had a leaking plug since I started using the Nealy brand plugs!
blaustrom likes this.
realshelby is offline
post #8 of 31 Old 01-17-2019, 04:36 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
The reason why its always a Phillips head screw is it easier to find the center of the screw in the dark and apply enough torque to get it through the carcass of the tire.
Sounds like a notacop post doesn't it.
richlandrick is offline
post #9 of 31 Old 01-17-2019, 04:53 PM Thread Starter
larolco's Avatar
I prefer Robertson head screws, myself. They are a wonderful invention and I don't understand why they aren't more widespread outside of the construction industry.
I think why you don't find them stuck through your tire is that they never fall off your screwdriver in the first place.
(Could be that, or my magnetic bit...)
Eastbayview likes this.
DRZ400SK17
larolco is offline
post #10 of 31 Old 01-17-2019, 05:21 PM
"Sounds like a notacop post doesn't it."
Yeah, but...my damaging bolt went in head first. Hole was way too big for a worm job.
I'll look for the Nealy brand. Seems the kit gets beat to death in the trunk and should be replaced once a year or so anyway.
07 DL1000 won’t start after running fine all day Jason Dion DL1000 from 2002-2012 22 09-02-2018 07:38 PM
Starts & runs fine when cold, engine starts to misfire when warm mushu DL1000 from 2002-2012 10 06-18-2018 10:42 AM
highbeam out.. bulb is fine varglesnarg Maintenance, Tech and Products. 2 03-19-2018 02:05 AM
2012 turn signal switch not working, hazards work fine ncrider V-Strom Service and Maintenance Questions and Discussions 12 08-09-2016 04:44 PM
Weld 86 Skid Plate-- A Fine Install Vangky DL650A - 2012-2016 12 11-19-2014 08:57 PM
