My 650 started leaving it's mark. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 13 Old 09-27-2018, 07:02 AM Thread Starter
Bucket's Avatar
I noticed last weekend that there was a couple little oil spots on the garage floor under the bike. I had just changed the oil a couple weeks before and figured I just missed them during clean up. Well, last night I noticed a new one. The drain plug is clean. Actually, the whole bottom is clean. It looks like there is a little up on the engine, but the wind has pushed it all over the place. I'm going to spray it down and clean it up real good and see if I can figure out where it's coming from.
It only has 24k miles...so I doubt it's anything major.
2013 White Glee...farkles added daily.
Bucket is offline
post #2 of 13 Old 09-27-2018, 05:46 PM
Doncha hate it when a bike gets incontinent and starts spotting on a clean garage floor?At 99K miles my engine gets dirty but I don't see floor spots since i fixed a leaky fork seal.
Happy hunting for the culprit.
post #3 of 13 Old 09-27-2018, 07:17 PM
branthopolis's Avatar
Another possible source of small random oil drips under Stroms, SVs, and TLs.....If you are running oil level near top of window and are doing a bit of higher speed/rpm, some oil can vaporize, blow back into & collect in the airbox... Check the little drain hose from the airbox that dumps out at the bottom of the bike...
Bucket, Gert and RestoRider2017 like this.
~Mark
2015 DL1000A
2005 YZ250
branthopolis is offline
post #4 of 13 Old 09-27-2018, 09:45 PM
kd70qc's Avatar
KN138 Leak
Do you have a KN oil filter?
File Type: jpg EFE3D23A-BF2D-4366-98D6-E47AA3524AE5.jpg (404.4 KB, 19 views)
File Type: jpg 160BFDD5-7E53-4BB3-B06D-82002F3E012A.jpg (640.0 KB, 19 views)
2015 DL650XT w/ factory Suzuki/Motech side cases and engine guard.
First farkle - Motech center stand
Suzuki handguards
Augustus Wind Deflectors
Fat, foamy grips
Givi AirFlow windscreen
Go-Cruise throttle lock
JD Astar 1260 lumen LED tail light bulb
Suzuki (SW Motech) Top Case
Hyde Racing skid plate
Adventuretech kickstand foot, fork brace, fender raising kit, and peg lowering kit.
Zita 26mm up / 20mm back risers
Sit and Fly Seat Net
So God created man in His own image; in the image of God He created him; male and female He created them. Genesis 1:27
kd70qc is offline
post #5 of 13 Old 09-28-2018, 06:58 AM Thread Starter
Bucket's Avatar
This is my suspicion, but till I get it all cleaned up, I won't know for sure.
Bucket is offline
post #6 of 13 Old 09-28-2018, 06:59 AM Thread Starter
Bucket's Avatar
Nope. I believe it's a Fram.
Bucket is offline
post #7 of 13 Old 09-28-2018, 10:44 AM
Fox
Fox's Avatar
Mine has been weeping oil from the frame sliders and oil cooler for a very long time. Doesn't seem to be getting any worse, but I do have a new oil cooler on hand with aluminum crush washers just in case it does.
Seems to be a thing: https://www.stromtrooper.com/dl650-d...-oil-leak.html
It's not something I worry about anymore.
Fox is offline
post #8 of 13 Old 05-15-2019, 02:15 PM Thread Starter
Bucket's Avatar
This seems to be the problem. And it is getting worse. With only 25k miles, it may be enough for me to unload and look at something different. I don't mind the occasional spot on the floor, but when it's on my boots, that's too much.
Bucket is offline
post #9 of 13 Old 05-15-2019, 05:58 PM
Fox
Fox's Avatar
Yikes, and that's coming out the engine mounts? If it's just the cooler or lines, I'd bite the bullet and replace both. You can get coolers and lines on ebay listed for the SV650 for next to nothing and they go on pretty easily.
Fox is offline
post #10 of 13 Old 05-16-2019, 06:32 AM Thread Starter
Bucket's Avatar
Yes, the problem seems to be a break in the case gasket that allows oil to get into a void that the motor mount bolt goes thru. At least that is what others have found.
Hatchi likes this.
Bucket is offline
LF: Trips leaving ontario in the next few days? bigfoot0 Canadian Troopers 1 08-04-2009 08:02 AM
Started her up today - had fuel leak jawmail DL1000 from 2002-2012 2 01-26-2009 10:36 AM
Leaving Wee on centerstand in wind? airtrons DL650 and DL650A - 2004 to 2011 12 07-31-2008 11:22 AM
