Fork oil - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 2 Post By Jimding
post #1 of 5 Old 09-04-2018, 12:09 PM Thread Starter
Fork oil
Rediscivered this recently. Thought it would be of intrest.It is a good overview covering most all fork oils. Fork oil weights. Somewhere along the way I found a reference to Dextron 3 being 35-40 centi and Dextron 6 as 30 centi. Sorry I did not note the source of that.Cheers Doug
Hfxoldvolks is offline
post #2 of 5 Old 09-10-2018, 10:14 PM
Who?'s Avatar
I've used ATF as fork oil for years... I believe dexron is about 15wt and ford type C is about 11wt. I used dexron.
Who? is offline
post #3 of 5 Old 09-11-2018, 11:08 AM
I've never
I've never felt the urge to prove myself smarter than the engineers that designed the parts. If they specify fork oil, I use fork oil. Not to mention that you can fine-tune viscosity by mixing different weights until the suspension acts the way you want it to. Considering I change the fork oil every couple of years, the extra cost is negligible.
notacop and remoandiris like this.
Jimding is offline
post #4 of 5 Old 09-11-2018, 02:40 PM
PerazziMx14's Avatar
ATF is something like $3 per quart whereas fork oil in my area of the world is somewhere around $15 per quart. I'd rather take the $24 saved and buy 700 or 800 miles worth of gas for my motorcycle
In traditional 50 year old technology damper rod forks ATF is more than adequate.
PerazziMx14 is offline
post #5 of 5 Old 09-11-2018, 03:07 PM
Fox
Fox's Avatar
ATF has been riding in my ancient damper rod fork legs for over 50k miles without any issues. I didn't notice any difference after the rebuild aside from the fact that they weren't leaking anymore. Maybe it matters on the track?
Fox is offline
Possible to adjust front suspension on a DL1000 K2? Halisko DL1000 from 2002-2012 10 08-09-2017 02:31 PM
Fork Brace warning swisstrom DL650A - 2012-2016 45 04-22-2017 07:22 PM
Installing Racetech Springs with Gold Valve Emulators on 650 lacofdfireman Suspension and Tire Tech 18 11-23-2016 07:13 AM
Fork seal change CaliScott V-Strom Service and Maintenance Questions and Discussions 3 05-22-2016 12:57 PM
Fork oil height/sonic 1.1 springs hunt1moore DL1000 from 2002-2012 16 09-22-2014 07:23 AM
