loud horn Question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
  • 2 Post By Traveler
  • 1 Post By hunt1moore
  • 1 Post By drmonbowen
  • 1 Post By greywolf
  • 1 Post By Traveler
  • 1 Post By Stalky Tracker
post #1 of 9 Old 01-19-2018, 12:27 PM Thread Starter
Ennsync's Avatar
Question loud horn Question
I am thinking to get a Denalli loud air horn or some thing similar. What is your past or current experience with load horns , where did you placed yours, Didi you need any relay or modulator or just change the old horn with new?
here in the canyons, cars and some Harleys ignore us.
Thanks
Ennsync is offline
post #2 of 9 Old 01-19-2018, 12:57 PM
I placed my inside the right front cowling, easy if you have smaller hands, used an Eastern Beaver plug and play.
Has worked for 3 years which is more than the last one did, mounted outside on the left front of the engine.
Sounds LOUD!
eagleeye and Ennsync like this.
'15 Red DL650
Subaru Outback X/T
Brody Mtn Bike
Give 'em a twist, a flick of the wrist
That's what the showman said...
Traveler is offline
post #3 of 9 Old 01-19-2018, 02:06 PM Thread Starter
Ennsync's Avatar
Sounds LOUD!
Which horn you are using < could you please name the product company and product # ?
Thank you
Ennsync is offline
post #4 of 9 Old 01-19-2018, 06:37 PM
hunt1moore's Avatar
I used a Wolo Bad Boy. Most install it in the front fairing on the left side. There are a few posts regarding installs.
If you are going to be installing additional ele. components then I recommend installing a PC-8 from Eastern Beaver.
Ennsync likes this.
PC-V, TRE, CR8EIX , ECM, K&N, RDL, PR4, PC-8, EB H4, WERKS, Madstad 22", 17/43 gearing, AdventureTech: Fork brace, shelf, mirror extenders, SpeedoDRD, wheel spacer, Head's-Up voltage monitor, Goldwing pegs, Sonic 1.1, Wolo Bad Boy, ExTuff Helmet Hook.
hunt1moore is offline
post #5 of 9 Old 01-19-2018, 09:06 PM
drmonbowen's Avatar
Thank you
I would strongly suggest that you buy the cheapest Stebel Nautilus clone that you can find. I've bought genuine Stebel and clones and the quality has never varied.
My second suggestion is that you toss the relay that comes with the kit and buy a "known good" relay rather than an el cheapo. My last two horns came with relays that simply did not work.
eBay has a ton of these horns, and here's an example.
Ennsync likes this.
drmonbowen is offline
post #6 of 9 Old 01-19-2018, 11:09 PM
I've used the stock relays with no problem. Their demise is caused by water entry. Get the relay under the plastics and point the lugs downward and it will be fine.
Ennsync likes this.
post #7 of 9 Old 01-20-2018, 06:21 PM
Thank you
https://www.revzilla.com/motorcycle/...mpact-air-horn but you can find it aplenty on Googlie.
Ennsync likes this.
'15 Red DL650
Subaru Outback X/T
Brody Mtn Bike
Traveler is offline
post #8 of 9 Old 01-22-2018, 10:50 AM
Stalky Tracker's Avatar
I have been running the Stebel Nautilus Compact Dual-Tone since early 2009 and no issues. I used the Eastern Beaver Horn Relay/Wiring Kit. It's mounted up under the left side cowling so there is some protection from the elements. It's loud and still going strong.
Ennsync likes this.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #9 of 9 Old 01-26-2018, 03:16 PM
drmonbowen's Avatar
You know how much respect I have for your knowledge and experience, Mr. Wolf. But the last two clone horns I have installed have arrived with generic and non-functional relays. I bought 12 known good relays and now just automatically replace the "free" one with one of mine. Problem solved!
