Heated Grips/Controller ID - Troubleshooting? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 12-13-2017, 10:57 PM Thread Starter
WeeBee's Avatar
My Heated Grip on the throttle side has quit working and I need to troubleshoot. Grips were already installed when I got the bike so I haven't a clue as to how these are typically installed or where the problem might lie. I've included a photo of the grip controller in the hope someone knows what brand they are or might have experienced a similar problem and might know of a fix for it.
2008 DL650 BumbleBee Edition
!!!BOYCOTT SV RACING!!!
WeeBee is offline
post #2 of 4 Old 12-13-2017, 11:13 PM
The heated grips are old style OEM Suzuki grips. They are famous for failing. Don't bother trying to fix them. Aftermarket grips like Oxford or HotGrips are a better choice for a lot less money.
post #3 of 4 Old 12-14-2017, 01:55 PM Thread Starter
WeeBee's Avatar
Thanks for the quick reply. Of the two you recommended, which one would you say is superior in performance/design?
WeeBee is offline
post #4 of 4 Old 12-14-2017, 02:23 PM
There are several makes that work well, I just mentioned a couple of them. I used HotGrips model 475-875 on two bikes along with Warm & Safe heat Trollers. Oxfords come with a heat controller. I wired HotGrips to a fuse block that was relay controlled so they were off if the ignition was off. I preferred that to wiring directly to the battery though at least some Oxfords turn off automatically after a short time if connected to the battery.
