Fuel range meter not working - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 1 Post By spike55_bmw
  • 1 Post By greywolf
  • 1 Post By V-Tom
post #1 of 10 Old 12-06-2017, 12:40 AM Thread Starter
I have discovered that my Fuel range function isn't working =. It reads _ _ _ _ _ _ range (blank)
It happened after it failed to start caused by a poor connection at the battery earth lead to to rear of the crankcase, which I have repaired.
Do I need to fill the fuel tank up to get it to recalculate the distance to empty?
Its already over 3/4 full of fuel.
All other functions of the dash are working as normal.
I have disconnected the battery which didn't change anything, same blank fuel range.
I Have ridden it around 10 kilometers, but no change
Does anyone have any ideas on what I could do next??
scottsdl is offline
post #2 of 10 Old 12-06-2017, 12:45 AM Thread Starter
I forget to list the Model!
Its a 2014 DL 1000A.
scottsdl is offline
post #3 of 10 Old 12-06-2017, 06:05 AM
pvwheeler's Avatar
I would suggest you just wait and see. It takes a while to figure out the range after a battery disconnect.
2015 Wee2 EXP "Arya"
2002 DR650 SM "Tormund"
2014 CB500x (wifes)
2018 XT 250 (wifes)
pvwheeler is offline
post #4 of 10 Old 12-06-2017, 06:16 AM Thread Starter
Thanks, Pvwheeler
Hope it does, if it doesn't recalculate I might take it back to our local dealer later this week and see if they can help.
scottsdl is offline
post #5 of 10 Old 12-06-2017, 07:44 AM
spike55_bmw's Avatar
Didn't know that the V-Strom could tell you what you had left in miles / km without back calculating miles traveled versus approx 250 miles to get serious about a gas station.
Burque73 likes this.
spike55_bmw is offline
post #6 of 10 Old 12-06-2017, 08:52 AM
It can take quite a while for the range figure to return if the ECM loses power and it has to start all over again. Try filling the tank first and riding for a while. Also, do not rely on the range figure to decide when to fill up. Do it after the icon starts flashing and certainly after the last bar starts flashing.
Lrobby99 likes this.
post #7 of 10 Old 12-06-2017, 09:37 AM
V-Tom's Avatar
The calculation is zero'd with a dead battery or anytime it sees no voltage. It takes about 10 km/6 miles for the range to empty to work so you just need to go for a ride. I suspect it bases it's readout on the average fuel mileage over the last 10 km/ 6 miles.
..Tom
SMIDSY detailed report.
V-Tom is online now
post #8 of 10 Old 12-06-2017, 04:48 PM Thread Starter
Hi all,
I will take it for another ride and see if it calculates distance to empty (range) after I run its close empty and refill it.
Thanks everyone for your help.
scottsdl is offline
post #9 of 10 Old 12-07-2017, 02:17 AM Thread Starter
Thanks Everyone,
I got it working again.
1 Drained fuel tank
2 Put in 2 litres
3 Took it for short ride, and within a few minutes it was displaying 15 KM range to empty
4 Filled it up full.
5 Now shows 420 range, which changes depending on AVG km/lt.
So its all back to as it was.
scottsdl is offline
post #10 of 10 Old 12-07-2017, 09:09 AM
V-Tom's Avatar
Originally Posted by scottsdl View Post
Thanks Everyone,
1 Drained fuel tank
2 Put in 2 litres
You didn't need to drain and fill again. All you needed to do is ride it.
A little note:
The range to empty seems to base it's calculation on the last 10 km/6 miles (or so) traveled. The average fuel mileage is based on the mileage since the last reset. In my case I reset trip 2 when I fill )and reset trip 1 at the beginning of any travels.) If you went for a ride of 10 or 20 km (6 to 12 miles) of higher speed riding (say 140 kph/85 mph) you might find your range to empty has dropped to 300 km/180 miles total mileage while you average fuel millage might work out looking like 400 km/240 miles.
..Tom
Solo Moto likes this.
V-Tom is online now
