Relay info needed - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By dravnx
post #1 of 10 Old 11-11-2017, 12:46 PM Thread Starter
zener's Avatar
Relay info needed
I want to mount a pair of 10 watt LED aux. lights which I want on all the time the bike is running - no on/off switch needed. I could buy a $30 harness with relay but I'd rather just put together my own since I already have the wire and don't need a switch. I've done an ebay search and come up with 5000 hits but from what I can see, they're mostly flasher relays. Does anyone have a link to a relay for this application similar to what comes in an aux. light harness? I think it would need one wire (or post) to connect to a switched wire on the bike, one positive to the battery, one negative to the battery, and one output to the lights. I might even be able to pick one up at a local auto parts store if I knew what to ask for. Thanks for any info!
zener is offline
post #2 of 10 Old 11-11-2017, 12:54 PM
You want an SPST automotive relay, commonly used as a horn relay. It will have terminals marked 85, 86, 87 and 30. An SPDT relay will work fine too. It will have an 87A terminal you just leave unused. See Understanding Relays (PDF Link)
post #3 of 10 Old 11-11-2017, 02:10 PM Thread Starter
zener's Avatar
Thanks GW! Just what I needed.
zener is offline
post #4 of 10 Old 11-17-2017, 10:12 AM
Curious
Is there a circuit already present that would handle an additional two amps (tail light?)? Not a lot of current. A simple wire tap would certainly be more reliable than extra wiring and a relay.
Jimding is offline
post #5 of 10 Old 11-17-2017, 10:45 AM
dravnx's Avatar
Any automotive parts store will have a relay. They're only a few bucks.
notacop likes this.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
smiles miles=bike.
It's simple math.
https://www.directavionics.com/
dravnx is offline
post #6 of 10 Old 11-17-2017, 10:51 AM
The heated grip connector on most models and the auxiliary/power connector on later models can handle two amps.
post #7 of 10 Old 11-17-2017, 09:29 PM
I got mine at the corner Autozone Store.
Use some big fat 12Ga wire to feed from the battery and back to the neg on the battery for best current flow.
post #8 of 10 Old 11-22-2017, 06:10 PM
Like Greywolf said. Best option.
Willie is offline
post #9 of 10 Old 11-27-2017, 10:34 AM
guitstik's Avatar
I bought a set of LED lights from Amazon and got what I thought was a "single set" of relay and connector for $8, but what I got was a box of six relays and connectors and they even have a fuse. If you haven't bought it yet let me know and I will send you one just for the cost of shipping.
guitstik is offline
post #10 of 10 Old 11-27-2017, 10:45 AM
Bugzy's Avatar
While you are at it, add a fuse block too, then you are ready to add more things in future. All bikes should have this IMO.
Bugzy is offline
