Rostra Cruise Control Intermittent Failure - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 10-23-2017, 06:41 PM Thread Starter
I've had a Rostra cruise control on my 2014 DL650A for about 3+ years. I use it all the time, even on short rides if i get a little open road.
Lately, starting on a recent long trip, I've had some intermittent failures. Every day it would start up and engage cruise as soon as I asked for it, working flawlessly. At some point later in the day ... almost every day of a two week trip ... when I tried to reset (using "set" as opposed to "resume") it after disengaging, it would fail to re-engage. A few times it even dis-engaged on its own as I was riding down the road.
Generally when this failure happened, I would turn off/turn on the unit and try again with no luck. Then I would turn it off and leave it off for a long while. Later when I came back to it, most of the time it would work fine.
Any ideas? Is this just the switch failing due to being exposed to the elements?
Chris
2014 DL650 - Red
Former bikes ...
2005 DL650 - Red ... totaled Aug-2013
2007 Yamaha V-Star Silverado 650 - Black & Blue ... sold
1984 Honda Magna V45 (700 cc) - Black ... sold
2001 Honda Elite 50SR (hopped up to 72cc ... woo hoo!!!) - Red ... sold
TVdoorknob is offline
post #2 of 7 Old 10-23-2017, 07:39 PM
Rolex's Avatar
The first thing I would check because it is easy.
Is check you have enough slack in the rear brake light switch to ensure the brake light is not staying on (very common on bikes) and ensure your right boot is not switching the brake light on accidently.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #3 of 7 Old 10-23-2017, 08:06 PM
Intermittent electrical problems are the hardest to diagnose. Checking the brake light is a good idea as the unit gets its ground connection through the brake light filament. A loose or failing filament or the brake light coming on will cancel the cruise control. See if replacing the bulb helps.
You coul go through the LED response tests but they will only help when the problem is active.
post #4 of 7 Old 10-24-2017, 12:39 AM
larolco's Avatar
FWIW, it was water getting into my switch that spelled the end of mine.
I never did bother to replace it since I've rarely felt the need to use the CC after doing the Iron Butt which prompted its installation.
The brake light theory sounds like a good place to start. Then the switch if you suspect water intrusion. Another possibility is a bad wiring connection but that's a bit more work to trace. I think I'd probably re-do all the connections if I didn't see something else obviously wrong. PITA though.
DRZ400SK17
larolco is offline
post #5 of 7 Old 10-24-2017, 01:07 AM
I had two wiring problems. The first was a broken wire to the control pad. The soldered connections moved wth the steering and the motion caused a wire to break at the end of the solder flow. The other was a bad solder joint. I wrapped a CC wire around a stock wire and when I soldered it I only got the solder on the CC wire.
post #6 of 7 Old 10-26-2017, 11:15 AM Thread Starter
Thanks for the suggestions. Will try the brake light and probably get a switch ordered as well.
While I'm at it I may as well pick up an Omni-Cruise or Vista Cruise to carry as a back up.
Chris
2014 DL650 - Red
Former bikes ...
post #7 of 7 Old 10-26-2017, 02:18 PM Thread Starter
Does anyone know if the Rostra cruise control switch is just sending a resistance signal to the main unit? I would be interested in building my own CC controls (in an effort to get larger buttons and more weather resistance) but if it's any more complicated than resistors, it could be out of my sandbox.
Chris
2014 DL650 - Red
Former bikes ...
