ABS switch kills speedometer. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 14 Old 09-24-2017, 03:05 PM Thread Starter
Fynlcut's Avatar
So I spliced into the white/yellow wire in the ABS connector. Added in a switch and can now turn the ABS off and on as needed.
Problem is, when the ABS is off, the speedometer goes to 0.
What did I do wrong.
'17 wee.
Fynlcut is offline
post #2 of 14 Old 09-24-2017, 03:30 PM
I would imagine the speedo gets its reading from the ABS sensors, like the Vee2 does, rather than having a separate speedo sensor.
post #3 of 14 Old 09-24-2017, 03:34 PM Thread Starter
Fynlcut's Avatar
So that is just the way it goes then?
Guess I don't really need to know how fast I'm going off road anyway.
Fynlcut is offline
post #4 of 14 Old 09-24-2017, 04:30 PM
It's an educated guess. I don't have a wiring diagram on the '17. I was thinking the same thing. If the place you're on is so gnarly you want to turn ABS off, you don't need a speedo.
chicago likes this.
post #5 of 14 Old 09-24-2017, 10:20 PM
chicago's Avatar
some have installed a bicycle speedometer and of course many use gps.
that way you could follow a scroll sheet etc.
14 tooth for me
chicago is online now
post #6 of 14 Old 09-25-2017, 10:29 AM
I wonder
Can you cut power to the ABS control box (the one with the pumps) rather than cutting the speed input line? Presumably that would preserve your speedo. Probably need a heftier switch.
Jimding is offline
post #7 of 14 Old 09-25-2017, 02:45 PM Thread Starter
Fynlcut's Avatar
I think I could splice into either the control line or the motor line for the ABS and kill it with the switch. Somehow I got it in my head the white with yellow (RWS) was the one I wanted. Obviously it works, but not the best choice.
I think I will follow the same philosophy as seen in the "Proper ABS on/off switch" post.
See what wire comes from the 10 amp ignition fuse to the ABS connector.
Fynlcut is offline
post #8 of 14 Old 09-30-2017, 10:21 AM
spike55_bmw's Avatar
For my ABS management, I use the Eastern Beaver plug to plug with off/on switch mounted on the dash. My speedo (2015 650XT) works fine with / without ABS functioning. I do have to turn the engine off / on to rearm the ABS after completing a dirt section.
Scott_J and brutalguyracing like this.
spike55_bmw is offline
post #9 of 14 Old 10-02-2017, 12:26 PM
Bugzy's Avatar
Does the odometer also stop working when the speedo switches off?
Bugzy is offline
post #10 of 14 Old 10-02-2017, 12:28 PM Thread Starter
Fynlcut's Avatar
I didn't verify the odometer readings did not progress, but the trip miles do not progress.
Fynlcut is offline
