TKC70 mounting direction? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 2 Post By bwringer
  • 1 Post By MontanaGuy
post #1 of 5 Old 09-23-2017, 12:11 PM Thread Starter
Hi.
I have a question about tire mounting.
I bought the Continental TKC70 for the front of my Wee.
The direction arrow is confusing. It uses the word "Front" and not the word "Rotation" or anything. If it is installed facing the direction of rotation then the word is upside down. If installed with the word "Front" right side up the arrow points counter-rotation.
Which is correct?
Thank you for your help.
You guys are awesome.
AZ_circus is offline
post #2 of 5 Old 09-23-2017, 01:12 PM Thread Starter
Based on images I found online of the tire mounted on various bikes I think I will point the arrow clockwise and ignore the word.
post #3 of 5 Old 09-23-2017, 01:24 PM
bwringer's Avatar
Yep. Use the arrow to determine mounting direction. Don't worry about the word.
Brockie and AZ_circus like this.
bwringer is offline
post #4 of 5 Old 09-23-2017, 09:08 PM
MontanaGuy's Avatar
I suspect the word Front means that it a front tire, not a rear. And, not to be used as a rear.
Brockie likes this.
Current Motorcycles
2007 Wee
2010 BMW S1000RR
2001 Suzuki SV650S
2005 Vee R.I.P.
MontanaGuy is offline
post #5 of 5 Old 09-23-2017, 09:49 PM
Sometimes a tire can be used front or rear. Weird, I know but it happens. If it says Front with an arrow, point it that direction. Otherwise mount it in the opposite direction if you happen to use it on the rear.
