Front sprocket - don't make my mistake - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 19Likes
post #1 of 30 Old 09-06-2017, 07:16 PM Thread Starter
Thighrod's Avatar
Last night I set about changing the chain and front sprocket on my 2015 650. The chain had become progressively more difficult to keep from drooping right after adjusting it, so I figured it was time.
Also, as my Wee is approaching 30,000 km (18,000 miles), I figured I would change the front sprocket at the same time, whether it looked like it needed it ir not. What I saw upon removing the sprocket cover surprised me. The sprocket was worn way beyond expectation.
Once again, besides premature slackening, the chain was showing no signs of failure. I've been contentious in lubing it since day 1, and don't ride in a lot of dust or mud.
So word to the wise: have a peek under that front sprocket cover every once in a while, you may be surprised by what you see (I was).
Sent from my SAMSUNG-SM-G870A using Tapatalk
Spec, Vaseface and NorcalDL1000 like this.
- Suzuki V-Strom DL650 (2015)
- Honda CRF 250L (2014)
- Triumph Street Triple (2016)
Thighrod is offline
post #2 of 30 Old 09-06-2017, 08:34 PM
Wow... so I can only imagine what my 27,000 mile original front sprocket might look like. I better have a look soon. Thanks.
MariusD is offline
post #3 of 30 Old 09-06-2017, 10:32 PM
kd70qc's Avatar
I've got 16k miles and mine has much less wear than that.
2015 DL650XT w/ factory Suzuki/Motech side cases and engine guard.
First farkle - Motech center stand
Suzuki handguards
Augustus Wind Deflectors
Fat, foamy grips
Givi AirFlow windscreen
Go-Cruise throttle lock
JD Astar 1260 lumen LED tail light bulb
Suzuki (SW Motech) Top Case
Hyde Racing skid plate
Adventuretech kickstand foot, fork brace, fender raising kit, and peg lowering kit.
Zita 26mm up / 20mm back risers
Sit and Fly Seat Net
So God created man in His own image; in the image of God He created him; male and female He created them. Genesis 1:27
kd70qc is offline
post #4 of 30 Old 09-06-2017, 10:47 PM
V-Tom's Avatar
Good reminder!
I have had two sprockets on my 2006 DL 650 that were worse than that before I clued in. They were at 66,000 and 62,000 km (think around 35,000 Miles.) Now I check and replace earlier... around half of my expected chain life so I am doing it closer to 50,000km or around 30,000 miles.
..Tom
Rides2Work likes this.
SMIDSY detailed report.
V-Tom is online now
post #5 of 30 Old 09-07-2017, 07:55 AM Thread Starter
Thighrod's Avatar
Originally Posted by V-Tom View Post
Good reminder!
..Tom
Yeah, I was always under the impression that a sprocket would typically outlast a chain, all things being equal. I guess that is not always the case.
Thighrod is offline
post #6 of 30 Old 09-07-2017, 08:39 AM
That looks like an OEM front sprocket. That is worn way past out!
Front sprockets should probably be changed at least once during a chains life in my experience. The smaller the front sprocket, the more rapid the wear.
V-Tom and Lrobby99 like this.
realshelby is offline
post #7 of 30 Old 09-07-2017, 10:36 AM
Rmplstlskn's Avatar
Speaking of sprockets, many out there are solid steel, while the OEM has a rubber bushing, as I have been told. Is this true? I have been told that the solid steel sprockets are a harsher ride due to lack of this rubber bushing.
Rmpl
2011 V-Strom DL650A Black w/ABS
Rmplstlskn is offline
post #8 of 30 Old 09-07-2017, 10:38 AM
OEM and one aftermarket maker offers the front sprocket with the rubber bonded to it. As far as I know this has nothing to do with ride but is simply a damper for noise. And it works, the ones without this do have noticeably more chain sing.
Old Time Rider likes this.
post #9 of 30 Old 09-07-2017, 10:51 AM
blaustrom's Avatar
This is really excessive wear for the mileage. You must be riding in conditions where the chain picks up grit that grinds down the sprocket. If this is so you may be better off with a dry chain lube that does not attract dirt much or at least a lot less lube than you may have used.
Also the front sprocket is symmetrical, means you can turn it around at 10k and have the "new" side of the sprocket in contact with the chain under load.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #10 of 30 Old 09-07-2017, 12:46 PM
yeah, the rubber on the sides of the OEM front sprocket is for noise dampening. I learned that last week when I did my first chain and sprocket replacement at 32,000 miles. Although, whether you can tell it dampens noise is up for grabs. I ended up with a new front sprocket that doesn't have the rubber bushings. I can't tell if it make more or less noise. In fact, with the new chain and sprockets, it almost seems to be running quieter over all. BTW, the front sprocket that I took off my bike didn't have anywhere near the wear that Thighrod posted.
Yarz1 is offline
