Cutting down kickstand - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By NVDucati
  • 1 Post By Wallydog
post #1 of 8 Old 08-27-2017, 06:51 PM Thread Starter
chirosyd's Avatar
Looking to shorten kickstand on my
2014 1000. Installed Soupy's lowering link and adjustable kickstand. Not loving the kickstand, and would like to have local welding shop shorten the o.e.m. kickstand. Soupy's kickstand as installed measures 8". Measuring the o.e.m. kickstand, it looks like it needs to be shortened 1 1/2 inches. There appears to be enough room directly above the bottom of the kickstand to shorten it the 1 1/2 inches. Has anyone done this and can chime in?
Thanks
chirosyd is offline
post #2 of 8 Old 08-27-2017, 07:47 PM
NVDucati's Avatar
I've shortened a few kick stands. I'm sure any welding shop can handle it.
As for suggestions;
Remove the stand from the bike.
Insert a short tube inside the two pieces you are rejoining.
If the welder offers a reason why either is not really necessary, you might consider the reply ... just humor me.
chirosyd likes this.
Member: AMA
NVDucati is offline
post #3 of 8 Old 08-28-2017, 01:30 AM
Rolex's Avatar
You can test your measurements by rolling the front and rear wheels up onto blocks of wood (same front and rear) and use the stand.
When your happy with the lean of the bike while on the stand measure the height of the wood blocks, this will tell you exactly how much you want removed from the stand.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #4 of 8 Old 08-28-2017, 04:14 AM
Wallydog's Avatar
Don't shorten it, simply grind off some of the metal from the stands 'stop' lug, this allows the stand to swing out further thus increasing the lean angle. Go slowly as it's easy to remove too much.
Cryoman likes this.
IBA 54971
Wallydog is offline
post #5 of 8 Old 08-28-2017, 09:02 AM
bwringer's Avatar
This can work, but it's a permanent change and will be a problem if he wants to sell the bike or raise it back to the proper height.
I suppose he could just replace the bracket if and when that time comes -- it's about $60.
bwringer is offline
post #6 of 8 Old 08-28-2017, 09:43 AM
The other problem with this method is it can be difficult at times to deploy the kickstand. If the bike is fully loaded or if there is any rise on the ground the kickstand can hit it in the downstroke.
If the kickstand is shortened, it can be lengthened by adding a taller foot if necessary.
wingstrom is offline
post #7 of 8 Old 08-28-2017, 05:14 PM Thread Starter
chirosyd's Avatar
Thanks for all your replies. I did a search, and it actually worked this time. I found a lot on the subject. I have decided that for now, I will use the Soupy's adjustable kickstand that was installed with the lowering link, and have gotten somewhat used to it. It does need a foot enlarger, and I just ordered that. I will keep the OEM kickstand for when I sell the bike, and put everything back to stock. Still love my Vee2, and feel much more comfortable now that it has been lowered.
chirosyd is offline
post #8 of 8 Old 08-31-2017, 07:47 AM
Location: Now living in Milton, Delaware and in the winter near Sarasota, Florida
I guess now we have to carry wood
Ride till you tire.... Then camp under the stars!
manofsteel1 is offline
