Quality LED bulbs - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 13Likes
post #1 of 37 Old 08-14-2017, 07:49 PM Thread Starter
OfirMX's Avatar
Quality LED bulbs
They are MUCH BRIGHTER than conventional lamps during day and night. I installed a couple of these H4's in the Strom and, man, they're bright!
- Yes, they do fit in the Strom's housing without any modifications.
- They are brighter than HID's and they don't need any warmup time.
- High beam/flash is instantaneous.
https://www.amazon.com/gp/product/B01KFBPBC0/
Lrobby99 likes this.
OfirMX is offline
post #2 of 37 Old 08-14-2017, 08:54 PM
Fox
Fox's Avatar
Says 72W, is that for the set or each?
Fox is online now
post #3 of 37 Old 08-14-2017, 10:01 PM Thread Starter
OfirMX's Avatar
36W each.
- Ofir
OfirMX is offline
post #4 of 37 Old 08-14-2017, 10:05 PM
Moderating in moderation
Vindex1963's Avatar
Mine are adjustable meaning you can loosen a set screw after they are locked in place and "focus" the light pattern by turning the bulb. Bright doesn't matter if it's spread all over.
OydnaR likes this.
2015 Suzuki V-Strom DL650 bought new 4/26/17
2015 Victory Cross Country bought new 7/11/15 (dyno tuned 118hp 116tq)
If it's not broken, make it better
My take on oil: Name brand, wet clutch compatible.....BAM good to go.
Vindex1963 is offline
post #5 of 37 Old 08-14-2017, 10:07 PM
NorcalDL1000's Avatar
Timely post. I've been thinking about switching to LED for my DL1000. thanks for the Amazon link.
NorcalDL1000 is offline
post #6 of 37 Old 08-14-2017, 10:11 PM
Vindex1963's Avatar
These are mine, no fans and adjustable light pattern. The rubber weather seals also work because you can unscrew the heat sink, install the rubber weather seals and then screw the heat sinks back on.
https://www.amazon.com/BPS-Lighting-...headlight+bulb
post #7 of 37 Old 08-15-2017, 06:39 AM
PineLaneRider's Avatar
Ofir,
How was the adjustment? I've been thinking about LEDs for a while but didn't want to lose focus or distance.
PineLaneRider is offline
post #8 of 37 Old 08-15-2017, 10:14 AM
[QUOTE=Vindex1963;4808226]These are mine, no fans and adjustable light pattern. The rubber weather seals also work because you can unscrew the heat sink, install the rubber weather seals and then screw the heat sinks back on.
How is the output with these?? Is the pattern good? Not blinding people? I might buy them if that all checks out. I've owned a few sets of the opt7 leds and have been happy with them but I hadn't seen these BPS ones before.
ehart814 is offline
post #9 of 37 Old 08-15-2017, 11:07 AM
Thanks
I am still hunting for a quality 1157 red LED for the brake lights. I bought one for $12 and it did not have the impact I expected. I am also considering a Adventure Tech modulator.
NewStrom
NewmarketStrom is offline
post #10 of 37 Old 08-15-2017, 12:02 PM
Vindex1963's Avatar
Bright
Pattern is up to you on how you focus them
Never had a car flash their brights
Originally Posted by NewmarketStrom View Post
Thanks
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old Time Rider and ehart814 like this.
