Glue recommendations - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 07-15-2017, 09:50 PM Thread Starter
Letsgo2up's Avatar
The rubber trim around the eye port is coming loose on my dirt bike helmet. It's a Scorpion. What glue would you recommend for re-attachment. Rubber or vinyl to fiberglass?
'06 DL 1000
'06 Bonneville T100
'01 Honda VTR1000
'09 Kawasaki KLX250
'07 Kawasaki KLR650
Letsgo2up is offline
post #2 of 4 Old 07-15-2017, 10:23 PM
RCinNC's Avatar
You could try Shoe Goo. It's a urethane based cement good for gluing the rubber soles of athletic shoes back on. It should work on vinyl.
There's also a cement called E6000, available at hardware stores, that works well in joining dissimilar materials.
RCinNC is online now
post #3 of 4 Old 07-15-2017, 10:59 PM
I used some industrial glue I had in the gun for the loose pieces on my Skorpion helmet. Used the same stuff on my loose hand grips too..
Locktite premium urethane adhesive.
post #4 of 4 Old 07-16-2017, 12:14 AM
E6000 is great. Amazing Goop II Max is similar and also great.
