Mystery mounting plate - anyone have one? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 1 Post By DesertBike
  • 1 Post By kiwi_outdoors
  • 1 Post By notacop
post #1 of 7 Old 12-23-2016, 03:27 PM Thread Starter
Onboard Mass Damper
DesertBike's Avatar
One of the previous owners of my K7 DL1000 put a mount for something on the right handlebar.
I haven't a clue what it was for. Does anyone have one of these? What does it go with? I haven't seen any branding on it anywhere, so there's not much to go on.
There are hex bolts on the lower portions for adjusting the angle of the plate, rotation of the collar that holds it on the handlebar, etc.:
For now, I'm using it as a mount for the wireless remote for my glove heat controller. This, by means of Velcro ties threaded through the larger holes you see.
2stroke likes this.
DesertBike is online now
post #2 of 7 Old 12-23-2016, 03:43 PM
I'd say for a radar detector.
2stroke is offline
post #3 of 7 Old 12-23-2016, 04:33 PM
GPS and camera are other possibilities.
post #4 of 7 Old 12-23-2016, 04:38 PM
kiwi_outdoors's Avatar
This?
TECHMOUNT - Products
This is our 3rd generation mounting system. We were able to combine all of the current production handlebar sizes from 7/8 (22mm) up to 1 (32mm) into one mount system. This allows it to fit virtually every motorcycle with tubular handlebars. Requires only of handlebar space and can be mounted at any angle. Available in Chrome, Black or Silver. Having no need for a shaft, makes this mount system very strong and very compact. Mounting Garmin ZUMO 660 requires P/N 60007 ZUMO Top Plate!
DesertBike likes this.
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
post #5 of 7 Old 12-23-2016, 08:51 PM Thread Starter
Onboard Mass Damper
DesertBike's Avatar
Yup, that's it! Thanks!
post #6 of 7 Old 12-24-2016, 12:07 AM
It's for a fragasrton. Eminently necessaary when going to warp speed. If you ain't got one, no need to worry.
jrnyer likes this.
post #7 of 7 Old 12-27-2016, 11:59 PM
It should also accept the newest generation Oscillation Overthruster.
Pirate650
2007 ABS Wee-Strom "The Silver Surfer"
2003 Kawasaki Concours "Mabel, the Flying Kaw"
Pirate650 is offline
