I think we need another recall....... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By Motor7
  • 1 Post By Motor7
post #1 of 6 Old 12-13-2016, 09:03 AM Thread Starter
Motor7's Avatar
....just kidding
I did a search and found about a dozen posts reference broken chain guard tabs....what the heck? All the threads I read involved the tupperware oem chain guard. The thing weighs what, about 3 ounces so I can't figure out what breaks the tab.
I replaced the plastic oem chain guard with a metal one, so I thought this might have been the cause. While in Moab, the forward tab which is welded to the swing arm snapped off. I zip tied it off and forgot about it until I pulled the rear wheel & shock last week.
I don't think any rock got through there large enough to do that kind of damage since there is not a mark on the guard. What think might of happened is that vibrations and general banging over rocks caused the guard oscillate at a weird frequency? Both bolts were very tight.
Now I have to figure out a way to get the tab welded back on. I can weld steel, but am not set up for aluminium. Looks like I will have to ride it to a shop and pull the rear wheel so a welder can get in there from the back side. I'm going to have them beef up the second tab while they are at it.
bobbyvstrom likes this.
15 DL650XT
Motor7 is offline
post #2 of 6 Old 12-13-2016, 04:41 PM
nvr2old's Avatar
I also have the fancy metal guard. My tab broke at 95 K miles. Was going to have it welded, but found a complete swingarm on E-bay(w/15K on it) delivered for $30.
A good welder might make it stronger than new though. Maybe have him reinforce the other one too.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #3 of 6 Old 12-13-2016, 05:30 PM Thread Starter
Motor7's Avatar
I do have access to a welder(Kieferbuilt aluminium horse trailers are built here), and I think you are right, some gussets on both tabs would probably take care of this issue. I'll post up a pic of the tab, and it looks like it was cracked 50% for a long time(discolored) before it snapped.
15 DL650XT
Motor7 is offline
post #4 of 6 Old 12-13-2016, 06:13 PM
Rolex's Avatar
The tab on my Wee broke off so I drilled and tapped 2 small holes in the swing arm, made up my own bracket and bolted it in place.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #5 of 6 Old 12-13-2016, 09:28 PM
Spec's Avatar
I don't believe that chain guards are necessary.
I take them off to make it easier to service the chain. I use a lube that doesn't fling off so my wheel stays clean without one.
Spec is online now
post #6 of 6 Old 12-14-2016, 08:08 AM Thread Starter
Motor7's Avatar
Now there's a thought!
Spec, I ran my '07 without one for 15K miles and I had a lot of lube build up(notorious over luber?) all over everything back there. I wanted a metal guard just in case that linked whip decides to break and lash out. But yeah, if I fix this and it breaks again, it's coming off for good.
Spec likes this.
15 DL650XT
Motor7 is offline
