Adventure Side Case with Givi Xstream 310 help - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 12-07-2016, 10:35 PM Thread Starter
SPD3454's Avatar
I have the adventure side case (SW Motech) and recently purchased the Givi Xstream 310 (Expansion Bag). The straps on the Xstream 310 are a little wider than the tie-downs on the side cases. I have been able to push and pull the straps through the side case tie downs, but it takes some time. I recently purchased the camp table, which also uses the tie-down points, so the expansion bag needs to come off. Does anyone have any ideas on how to make this a little quicker with the straps?
2012 V-Strom Adventure
SPD3454 is offline
post #2 of 5 Old 12-07-2016, 10:41 PM
Could you cut the straps a bit narrower and seal them with a flame to prevent raveling?
notacop is online now
post #3 of 5 Old 12-07-2016, 10:48 PM Thread Starter
SPD3454's Avatar
I would have no problem doing that for length, but was concerned they would pull apart when cutting the width.
SPD3454 is offline
post #4 of 5 Old 12-07-2016, 11:00 PM
Stalky Tracker's Avatar
If the straps are removable, could you just replace the straps with narrower ones?
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #5 of 5 Old 12-08-2016, 12:54 AM
How about attaching some narrower straps to the tie down points creating a loop then thread the 310 straps through that loop?
wingstrom is offline
