License plate attempts escape - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 14Likes
post #1 of 15 Old 11-25-2016, 09:00 PM Thread Starter
Onboard Mass Damper
DesertBike's Avatar
About halfway through a several-hour trip today, a passerby pointed out that my license plate was hanging askew, kept in place by only one of what originally was two of those blue reflector things with the wing nut (like these: https://www.amazon.com/Chris-Product...late+reflector).
Obviously, one reflector worked its way completely loose at some point. Pretty sure it was there this morning, so I can only imagine the vibrations from 10+ miles of gravel, dirt, and dirt-with-tons-of-embedded-rocks roads worked one of those things loose.
I can buy another reflector/fastener, but how do I keep this from happening again? Add "inspect license plate fasteners" to the pre-ride checklist? I had secured the existing ones with blue Loctite, but apparently that isn't enough.
I don't really want to put red Loctite on there. True, I'll never need to remove the plate unless I sell the bike, but red Loctite is a big pain in the ass to remove. I try not to use it when alternatives exist.
DesertBike is offline
post #2 of 15 Old 11-25-2016, 10:14 PM
Spec's Avatar
Get rid of the wing nuts and use nylock nuts.
Spec is online now
post #3 of 15 Old 11-25-2016, 10:18 PM Thread Starter
Onboard Mass Damper
DesertBike's Avatar
Ooo good call, easy too. I mean the wing nuts are nice for making it easy to put the things on, but those Nylok nuts won't vibrate loose. Thanks!
post #4 of 15 Old 11-25-2016, 11:11 PM
Lock washers have worked for decades too. Simple bits of hardware that have been around many long time.
post #5 of 15 Old 11-26-2016, 09:06 AM
Macdoc's Avatar
Tie wrap work the charm and really quick. I always carry a couple just for that sort of stuff
Big B and wingstrom like this.
Canada 2018 CB500x >2009 CBF1000 sold 10 Wee ABS sold 09 Burgman Exec sold 10 NT700v sold
Australia> 04 KLR650 93 ST1100 sold
Macdoc is offline
post #6 of 15 Old 11-26-2016, 09:42 AM
10MMVFR's Avatar
Maybe they were not tightened properly to begin with. I'd replace the wing nut, make sure it's tight and keep an eye on it until feel it won't go anywhere. That's how it happened for me.
10MMVFR is offline
post #7 of 15 Old 11-27-2016, 01:34 AM
Toshbar's Avatar
https://engineerdog.com/2015/01/11/1...out-fasteners/
cyclopathic likes this.
2014 One Thou Pow!
Toshbar is offline
post #8 of 15 Old 11-27-2016, 01:46 PM
Good information!
Past experience has lead me to be able to trust them despite their scientifically proven failure rate.
Bumble bee's aren't suppose to be scientifically able to fly either.
I've seen the vibration tests the quickly unraveled a lot of fasteners. Very fascinating. But failed under extreme conditions most of us don't experience on a bike.
If you can afford it and have a good local supply, always get the best you can!
If you have 40 years worth of left over hardware in the garage from a zillion projects, use what youse got!
Vhawg likes this.
post #9 of 15 Old 11-28-2016, 12:50 AM
bwringer's Avatar
I use stainless steel M6 nylon lock nuts and socket head hex screws on all my bikes.
No reason to make it so easy to steal the plate without tools.
Letsgo2up and Old Codger like this.
bwringer is offline
post #10 of 15 Old 11-29-2016, 12:12 AM Thread Starter
Onboard Mass Damper
DesertBike's Avatar
Yeah, I'm going to go with the nylon-insert lock nuts. The bike is parked in my garage or another relatively secure environment almost all the time, but there's no reason to take a chance of someone lifting my plate. It's just the sort of PITA property crime for which our city is notorious.
