Fork info post gone - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 11-03-2016, 08:08 AM Thread Starter
Fork info post gone
Could someone please explain why my request for fork info was moved or deleted?
It seemed a fair request for help, in a correct section on the forum.
UKPhil is offline
post #2 of 8 Old 11-03-2016, 10:12 AM
p38arover's Avatar
It's not gone. I can see it - but...
For some reason it's in the Moderation Queue awaiting moderation. I don't know why.
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
1979-2008 - Riding on forever
p38arover is offline
post #3 of 8 Old 11-03-2016, 10:28 AM Thread Starter
Ok, thankyou for the reply.
I'll keep an eye out for it popping back up and hopefully get some response.
Phil
UKPhil is offline
post #4 of 8 Old 11-03-2016, 11:32 AM
I managed to accidentally screw it up moving it to the Glee forum. I've fixed that. The general forum was not the proper place for it as the forks are different from earlier models.
post #5 of 8 Old 11-03-2016, 11:53 AM Thread Starter
Ok, thanks GW.
I deliberately put it in the general section hoping for a bit more coverage although I appreciate there are differences through the model years.
Phil
UKPhil is offline
post #6 of 8 Old 11-03-2016, 12:25 PM
The general forum is only for posts that involve multiple models. It does not attract more knowledge.
post #7 of 8 Old 11-04-2016, 05:04 AM Thread Starter
I was open to input for specs for the older 650s even though the damping characteristics may be slightly different.
Phil
UKPhil is offline
post #8 of 8 Old 11-04-2016, 11:09 AM
That still may happen but I'd be more surprised if you got any specs at all. Not many people have gone in there and it's likely nobody has the parts on the bench or has written down what they found when they did. For sure the springs are different on other models so the damper holes should also be different. The lighter springs on older bikes should have correspondingly smaller damper holes. Anyway, the forks on the older bikes definitely need help and the Glee forks, while better, still suffer from the similar damping force on compression and rebound because they force oil through the same holes on compression and rebound Minimally, cartridge emulators that use a device that makes compression easier than rebound are where people wanting better suspension should first look. Changing the damper rods to cartridges from Cogent Dynamics or Traxxion would be the best but most costly solutions.
I think the most helpful people here look at all new posts anyway no matter where they are posted.
As of now, the thread has no replies and that is not because of location. You are asking for information that is very hard to come by. Suspension and tire tech is another possibility for an appropriate forum. Do you want me to move it there? A Google custom search on Ricor or Race Tech may be helpful in gaining front suspension insight.
This thread has much more action than the thread it is about.
