Can't bring myself to spend so much money on luggage - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 38Likes
post #1 of 58 Old 10-11-2016, 09:42 AM Thread Starter
cavenger's Avatar
I need storage space because I want to take a longer trip on my bike. I can survive with my larger top case but it really only holds my jacket and pants when I am off the bike. That leaves very little room for grocery trips and other things... So I think I need side cases but I just can't pull the trigger on the matching givi cases. That crap is expensive. I just need to suck it up and do it!
Sent from my SM-G935T using Tapatalk
cavenger is offline
post #2 of 58 Old 10-11-2016, 09:46 AM
DaveinNC's Avatar
If I had to do it over again I wouldn't. I only use a top box, my panniers are on the shelf. I can go out for 2 months with a dry bag and top box. And yes, that stuff is expensive to just sit on a shelf.
iamsmiling, Spec and cavenger like this.
"Dave"
DaveinNC is offline
post #3 of 58 Old 10-11-2016, 09:47 AM Thread Starter
cavenger's Avatar
I have a 25 liter dry bag as well. It does get in my way on daily commutes though. Getting off is a bit of an old man gymnastics performance.
DaveinNC, Hank122 and Chris N like this.
cavenger is offline
post #4 of 58 Old 10-11-2016, 09:55 AM
eagleeye's Avatar
I can't imagine traveling without panniers, top box and the back seat and top of the panniers with stuff on them. But that's just me. I'd look for used panniers then.
2009 Suzuki DL650
2005 Yamaha RSTD
2002 Triumph Bonneville
1980 Yamaha XS650 chopper
The Best Bike is the Bike You Like
eagleeye is offline
post #5 of 58 Old 10-11-2016, 10:00 AM
RCinNC's Avatar
Or, you could use a set of these; I've had them on two different bikes now for a total of 44,000 miles. Still going strong.
Multicomp 22" Black Tactical Weatherproof Equipment Case | 22-24120 (2224120) | Multicomp
I made my own quick release mounting system, but there are also commercially available ones out there designed for Pelican cases that would also work. You'd probably have less invested in these cases than you would in buying a single Givi.
Nelson-Rigg makes a nice set of soft bags that you can just throw over the seat. I think the current model is CL-850.
File Type: jpg IMG_3033altered Route 19 south of Salem MO.jpg (96.6 KB, 105 views)
RCinNC is offline
post #6 of 58 Old 10-11-2016, 10:03 AM
NyMeTsFaN912's Avatar
Check out what Big B did with his Bestem top case. It's in a thread somewhere or you can ask him. I know he spent next to nothing and I got to see it first hand and it's just as good as some of the big names. I'm pretty sure you can do the same with side cases.
-John
NyMeTsFaN912 is offline
post #7 of 58 Old 10-11-2016, 11:09 AM Thread Starter
cavenger's Avatar
I made my own quick release mounting system, but there are also commercially available ones out there designed for Pelican cases that would also work. You'd probably have less invested in a whole system using these cases than you would in buying a single Givi.
I like the Tactical cases, but fitting the racks would require me having some sort mechanical skill which I have very little of. I haven't seen anyone sell cheap racks but if someone knows where, please point me there.
My givi top case is great, but I would be willing to sell it off to come up with something cheaper. Here's the thing, for me, I guess I am snobbish, I want it to match.
I have considered soft saddle bags as a temporary option, but then I just keep thinking, just get what you want.
eagleeye likes this.
cavenger is offline
post #8 of 58 Old 10-11-2016, 11:34 AM
That looks really good. Do you have a thread with more detail on the rack/mounts?
2002 DL1000: 75k miles. Bought at 50k miles.
1992 XJ600: Red, Very custom.
2002 Vespa ET4 150: The wife's ride.
Nelsonmd is offline
post #9 of 58 Old 10-11-2016, 11:51 AM
Get what you want and be done with it, but in saying that......why not just get some Givi racks, then you have so many options as to what you can mount up? Top loaders will be the most expensive, but not everyone has top loaders.
Hank122 likes this.
post #10 of 58 Old 10-11-2016, 11:54 AM
RCinNC's Avatar
I don't know what you would consider a cheap rack; Happy Trail has racks on sale now for a V-Strom for $245.00. Any decent set of pannier racks are going to be in that same ballpark (and probably more). I'd be really leery of a rack that was substantially cheaper, because I'd be wondering just how well it was constructed. Having a rack break during a trip is a sure fire fun-killer. I've used HT racks on my last two bikes, and found them to be very robust. You can check eBay for used ones; a lot of guys who sell their ADV bikes sell off their accessories first (I did).
Suzuki DL650 Luggage; Suzuki DL1000 Racks, V-Strom 650 2012
They also make a puck system for attaching luggage to the racks. It's designed for aluminum panniers, but I'm sure it would work on any flat sided luggage. Caribou makes an attachment system specifically for Pelican cases, but it's in the $200.00 range.
HT makes what they call an SL rack, which is mainly designed as a standoff rack to keep soft luggage from getting tangled up in the rear wheel. They run about $200.00. It's not that hard to make a soft luggage standoff from a piece of strap steel from the hardware store, but if you don't have some mechanical skill, that won't be a good solution for you.
Happy Trails SL Side Rack Suzuki DL650 V-Strom
You're going to be fighting an uphill battle looking for a luggage/rack system if you're trying to combine "cheap" with "no do it yourself fabrication skills". Even mine, with several homemade components, still probably cost me around $350.00 (the cases were a little cheaper back when I set mine up). Even if you just bolt the MCM cases directly to the racks without a quick release, you're still in at least the $350.00 range with current prices.
Some motorcycle accessories can be done cheaper, but very little involving a bike can be done "cheap". If you don't feel your mechanical skills are up to the task of fitting racks to a bike, you may be at a loss in trying to find a really cheap workaround solution for a luggage system.
Big B, Vhawg, cavenger and 1 others like this.
RCinNC is offline
