Mounting Locations for Switches - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 2 Post By swingset
post #1 of 7 Old 09-23-2016, 01:16 PM Thread Starter
OydnaR's Avatar
Now that I am getting closer to having my auxiliary charging system up and running , I am begining to consider switches and location for accessories I plan to add
I will need a bank of at least 4 switches for
fog lamp
driving lamp
rider heated seat
pillion heated seat
I'm looking at the illuminated rocker switches from Eastern Beaver, but they are huge
RichlandRick's auxiliary shelf doesn't really work cause it would hide my voltmeters that are recessed into the faring
looking for ideas or sources for smaller illuminated switches
IBA#9560
Copyright (c) 2019
OydnaR is offline
post #2 of 7 Old 09-23-2016, 03:42 PM
NVDucati's Avatar
fog lamp
driving lamp
rider heated seat
pillion heated seat
You don't say which bike you are doing this on ... still one thing to keep in mind is that you can have indicator lights that are separate from the actual switches. Doing that will allow you to have the lights in a visible spot but in a very small cluster. I'm assuming that you will be using a relay(s) so the lights and switches will not be highly loaded.
There are thousands of choices - If you really want the switch itself to be illuminated, here is one https://www.oznium.com/rocker-switch#photos
Member: AMA
NVDucati is online now
post #3 of 7 Old 09-23-2016, 04:51 PM
swingset's Avatar
Send a message via Yahoo to swingset
I used small illuminated rocker switches mounted on my cowl. Don't take up much space at all.
https://www.delcity.net/store/LED-Do...FZElgQod64oD4A
Big B and eagleeye like this.
swingset is offline
post #4 of 7 Old 09-23-2016, 08:20 PM Thread Starter
OydnaR's Avatar
I'm looking for switches that have both location illumination, and ON illumination
IBA#9560
Copyright (c) 2019
OydnaR is offline
post #5 of 7 Old 09-24-2016, 08:38 AM Thread Starter
OydnaR's Avatar
I really like the Series 3100 switches from Hella, completely waterproof,
https://www.hella.com/switchshop/index.jsp
if I can find a place to mount them, a panel attached to the handlebar ?
IBA#9560
Copyright (c) 2019
OydnaR is offline
post #6 of 7 Old 09-24-2016, 09:18 AM
MattR302's Avatar
I have one of these switches controlling my LED halos and my HID's on my FZ6, mounted on the inner fairing. It's a little big, but it fits my area well, easy to use with gloves on, and I only need one. Purchased on ebay for about $7.
These types are a center-off, double-throw switch. So in my application:
switch down, small light on = LED Halo's on (HID's off)
Switch up, large light on = HID projectors on (Halo's off)
Switch in the middle, no lights on = both halo's and HID's off.
Since you just need an on/off switch, you could also do a pushbutton type. I remember seeing some But unless you were using a relay for each, they'd need to be capable of handling the current through the heated seats and lights. You'll need to do extra wiring if you want them to have an "always on" location illumination.
MattR302 is online now
post #7 of 7 Old 09-24-2016, 11:12 AM
RCinNC's Avatar
How about something like this: https://www.amazon.com/Waterproof-Mi.../dp/B0039L0GKG
There are other similar choices on Amazon.
RCinNC is offline
