What is your buzz killer? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 12Likes
post #1 of 25 Old 09-20-2016, 10:35 PM Thread Starter
cyclopathic's Avatar
After farkling out for a couple weeks took my Glee on quick 350mi shakedown run.
With suspension upgrades runs really smooth, you could say even disconnected. The road vibes are non-existent. BUT it makes engine buzz in 4.5-6k range even more apparent.
Worse part it is in 65mph+ highway cruising range.. which makes going the distance quite tiring.
What did you do to your Wee/Glee to reduce vibes? What is your buzz killer?
cyclopathic is offline
post #2 of 25 Old 09-20-2016, 11:00 PM
blaustrom's Avatar
1. change gearing to reduce RPM's by 10%: 16 tooth counter sprocket and Me880 rear tire
2. change upper tripple tree clamp to Vee1000 version with rubber mounted handlebar holders. You can find them on e-bay. Note, not sure if the Glee has the same part number and dimensions as the WEE, you need to check. The WEE and VEE were the same dimensions, so a straight swap.
3. OEM bar end weights and steel handlebar, not thick walled aluminum, they don't dampen vibration well.
Those 3 changes made 75mph on the slab no problem for hours on end (mileage eater run from Denver to the east)
blaustrom is online now
post #3 of 25 Old 09-20-2016, 11:15 PM
V-Tom's Avatar
Fwiw I had no vibration issues at all on my 2012 DL650. 75mph/120 kpm is a pretty normal cruising speed and did it daily, sometimes all day.
I have heard that many sources of vibration are realities to "crash bars" and this is logical since they at least in part mount onto the motor mounts. (I never used them so that is probably why I never had any issues.)
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
Last edited by V-Tom; 09-21-2016 at 02:23 PM. Reason: speeling and correcting speel checker
V-Tom is online now
post #4 of 25 Old 09-20-2016, 11:17 PM
V-Tom's Avatar
I left mine stock.. Never an issue with vibes.
..Tom
My Opinion:
My Stroms:
V-Tom is online now
post #5 of 25 Old 09-20-2016, 11:23 PM
2wheelrob's Avatar
I like the foam over grips. I put some on because I have large hands and my hands would go numb grabbing the small grips. They do dampen the vibrations also and are cheap and quick to try (as long as you do not pull the bar end screw out all the way. Thankfully read about that before messing with mine).
You did not mention where you are feeling the vibrations. If you are feeling the vibrations through the seat, an air hawk pad may help. I have not used one but see a lot of them around.
2014 DL1000A
2002 BMW K1200LT
Some people just don't get how a 300+ mile round trip for lunch makes sense.
If you are reading this, you probably do.
2wheelrob is offline
post #6 of 25 Old 09-21-2016, 01:51 AM
Bugzy's Avatar
It could be your tires are just slightly out of balance and only noticeable at certain speeds, you might try dynabeads in them to see if that smooths things out. 1oz front and 2oz rear is maybe $15.
Bugzy is offline
post #7 of 25 Old 09-21-2016, 02:42 AM
Macdoc's Avatar
Grip Puppies or Grip Buddies for sure
VSrider and NyMeTsFaN912 like this.
Canada 2018 CB500x >2009 CBF1000 sold • 10 Wee ABS sold • 09 Burgman Exec sold • 10 NT700v sold
Australia> 04 KLR650 • 93 ST1100 sold •
Macdoc is offline
post #8 of 25 Old 09-21-2016, 06:47 AM
a) Take the crash bars back off. Smooth as
b) Put cycle frame bags on the crash bars, that damps the vibes.
PeteW is offline
post #9 of 25 Old 09-21-2016, 10:20 AM Thread Starter
Originally Posted by V-Tom View Post
Fwiw I had no vibration issues at all on my 2012 DL650. 75mph/120 kemp is a pretty normal cruising speed and did it daily, sometimes all day.
I have heard that many shares of vibration are realities to "crash bars" and this is logical since they at least in part mount onto the motor mounts. (I never used them so that is probably why I never had any issues.)
..Tom
I have ADV Glee with OEM crash bars, thanks for pointing it out. Found and still reading the big crash bars thread. Made some changes will see if it helps.
post #10 of 25 Old 09-21-2016, 10:24 AM Thread Starter
Unfortunately this is not an option. I just took off rather nice OEM grips and replaced them with hard like a rock heated grips. Puppies and buddies don't work well with heated grips.
