Durability of the Admore lighting kit? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 16 Old 09-13-2016, 06:41 PM Thread Starter
Thighrod's Avatar
Hello gents,
Does anyone have long term experience with any of the Admore LED products?
I ordered a light kit for my Givi E52 top box this spring and it has quit working (for no apparent reason). A bunch of back and forth has already taken place with Admore, and with the help of my multimeter, I think I've nailed down the problem to an issue in the part of the harness that steps the voltage down to the proper levels to illuminate the LEDs in the topbox.
Although I loved the product (when it was working), I am worried about its long term prospects. Given the cost (my kit was $220+ Canadian), I expected at least a few trouble-free years.
I have been instructed to send the offending harness back to Admore, where, upon receipt, they will examine and decide whether they will replace under warranty, if they don't determine that I caused the issue (somehow). I'm a little bummed that it'll likely end up being at least a couple more weeks or so before I get my enhanced rear visibility back, but we'll see what happens.
Any other Admore experiences out there/long term reports?
Thanks
Thighrod is offline
post #2 of 16 Old 09-13-2016, 06:57 PM
SECoda's Avatar
Well mine is about 20 months old and still working on a Givi V47. I have the full tail light set. I take it you are past the 12 month warranty? I would call them anyways.
Customer Service
Toll Free: 1-877-564-8100
SECoda is offline
post #3 of 16 Old 09-13-2016, 07:15 PM Thread Starter
Thighrod's Avatar
No, I bought mine in the February, it's been in use since April. Still under warranty.
Thighrod is offline
post #4 of 16 Old 09-13-2016, 08:11 PM
eagleeye's Avatar
Givi E-52
I'll be watching this thread as I just put one on my Givi E-52. If you haven't sent it in yet, you might check the fuse/connections, and terminal block to see if everything is where/how it is supposed to be.
2009 Suzuki DL650
2005 Yamaha RSTD
2002 Triumph Bonneville
1980 Yamaha XS650 chopper
The Best Bike is the Bike You Like
eagleeye is offline
post #5 of 16 Old 09-13-2016, 09:15 PM Thread Starter
Thighrod's Avatar
Yes, thanks, I already tested the voltage of each connector at every joint. Looks like the harness, the flat vinyl wrapped area between the distribution block and the connector that goes into the topbox, is the culprit.
Thighrod is offline
post #6 of 16 Old 09-13-2016, 09:37 PM
I had an admore light kit for my Givi top box, sorry can't remember which one, but it worked for 5 years just fine. I sold the bike so I don't know if it is still working. I have the light bar on my Glee and it's been working fine for 12 months now. I ride all year too.
coracle is offline
post #7 of 16 Old 09-13-2016, 10:22 PM Thread Starter
Thighrod's Avatar
That's great to hear. Maybe I just got unlucky with mine then. Thanks for replying.
Thighrod is offline
post #8 of 16 Old 09-13-2016, 10:27 PM
Mulewright's Avatar
After installing a 'double' kit in my V47 (top & bottom positions) I can say they have good warranty & most helpful customer support for the 1st year... under warranty.
They replaced the std. kit lights 2 times & the 'controller' 1 time.
The 'lid' mounted lights don't tolerate dampness at all well.
2nd Controller is doing fine also mounted under the seat... so far.
The 3rd set of lid mounted lights went bad 3 mos ago, the non std.'kit' lights supplied are still working just fine.
NOT the results I expected for the cash outlay.
I have other options I am checking out...
[B][I]~ Stretching the Limits of Performance & Good Taste ~[/I][/B]
Mulewright is online now
post #9 of 16 Old 09-13-2016, 10:54 PM
Stalky Tracker's Avatar
I've been running the Admore SMT light bar for about 15-16 months. No issues and works great.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #10 of 16 Old 09-14-2016, 10:23 PM
chicago's Avatar
I have used their products without issue in the past though I did have a light bar that had some non-working leds. A photo of the problem and a new one was on the way. My opinion is they are a first rate outfit. Good luck.
14 tooth for me
chicago is offline
