DR650 fork seals in DL650? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By greywolf
post #1 of 7 Old 09-11-2016, 01:47 PM Thread Starter
I did some Googling. It appears the DR650 and DL650 share fork tube sizes -- 43mm.
I'm in the process of doing a seal change on my V-Strom. I had bought the "Fork Solution Kit" from ProCycle a couple years ago and it included seals, which I didn't use at the time since mine were still good. So I tore everything apart today to do the job knowing I had seals.
Well turns out they're THE WRONG F'ING SIZE. I have a set of 41mm seals here that don't go to any bike I've ever owned. The only other set of fork seals I have here are for my DR650. They're 43mm. Would they work? If not, I'm screwed because it'll be several days before I can get the right size. Naturally it's Sunday and all the shops are closed, not like the local dealer would even bother stocking such a thing.
Rob
'17 Triumph Tiger 800XCA
'17 Kawasaki Versys-X 300
'04 Triumph Sprint ST
'96 Suzuki DR650
RobG is offline
post #2 of 7 Old 09-11-2016, 02:28 PM
There is more to seal size than inner diameter. Suzuki parts lists cross reference different models. Glee seals are unique according to Suzuki 51553-47H00 - OIL SEAL : MRCycles
The DR650 shares seals with the RM series. Suzuki 51153-14330 - OIL SEAL : MRCycles
post #3 of 7 Old 09-11-2016, 04:49 PM
Cal
Just changed my (2012ABS) seals and dust wipers with the Moose Racing 56 133 1
1 day delivery at my local dealer acouple sites say these do not fit the Glee but they did. The dust seals were a little tighter than the old OEM
Cal is offline
post #4 of 7 Old 09-11-2016, 07:10 PM Thread Starter
Thanks greywolf... I figured that was the case when the outer diameter was off by about 1mm. I ended up thoroughly cleaning the old seals and reusing them because I HAD to have the bike done today lest I have issues with where I live. So far, it seems to be holding up okay.
Meanwhile, I will order up a proper set of seals for when it inevitably starts leaking again sometime down the road (no pun intended).
'96 Suzuki DR650
RobG is offline
post #5 of 7 Old 09-11-2016, 08:00 PM
I installed gaiters over fork tubes on any bike I owned that doesn't come with gaiters ever since I had a fork seal leak on a Can-Am 175TNT. I never had a seal leak after that. Keep the fork tubes free of stone chips and dried bug parts and forget about seal problems.
post #6 of 7 Old 09-11-2016, 08:35 PM
booghotfoot's Avatar
That's a good tip. Can you recommend where to get them?
Sent from my KFFOWI using Tapatalk
There are 10 kinds of people: those who understand binary and those who don't.
New Rider May 2016
K9 Wee
booghotfoot is offline
post #7 of 7 Old 09-11-2016, 09:22 PM
Google gaiters site:stromtrooper.com
There are a ridiculous number of possibilities. I used Rancho RS1952 shock boots.
cyclopathic likes this.
