How Do You Check A Motorcycle¯s Oil Level? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By Motorcycle.com
  • 1 Post By Jimding
post #1 of 5 Old 09-02-2016, 10:23 AM Thread Starter
Editorial Content
How Do You Check A Motorcycle’s Oil Level?
Modern motorcycles are incredibly reliable, but they still require you to check a few things in order to keep them running at full potential. The engine oil is one of those items you should never neglect. After all, you don’t want to run your high-revving, manufactured-to-aerospace-tolerances, and extremely-expensive-to-replace engine without the proper lubricant, do you? Additionally, an engine’s oil can reveal a good bit of information about the condition of its internals to even a novice mechanic armed with a little information.
To actually check an engine’s oil level, take a look at its owner’s manual. Seriously, it’ll outline the specifics that the manufacturer recommends – and they do vary slightly from bike-to-bike. Still, the steps do follow a rough pattern.
Make sure the engine is warmed to operating temperature. After turning it off, allow the oil to drain down from the top end by waiting a few minutes. Bikes with a sight glass require that you hold the bike level – either from the saddle or beside the bike – look at the window conveniently located on the bottom of the engine to make sure the oil level is between the two marks on the case. (Tip: If your bike has both a centerstand and a sight glass, measure it the above way and then compare it to the level shown while on the centerstand. This way you can use that level as reference so can check the oil level when it’s parked on the centerstand in your garage.)
For engines with a dipstick, check your owner’s manual to make certain how the stick is to be inserted for an accurate reading. Usually, you will wipe the stick and insert it into the case until it makes contact with the filler plug’s threads. Be sure the plug is straight and the bike is level or you may get an inaccurate reading.
If you ride your bike regularly, you should check its oil at least weekly. If you ride infrequently, consider checking before every ride. With regular checks, you are more likely to notice symptoms of little problems before they get bigger.
Read more about How Do You Check A Motorcycle’s Oil Level? at Motorcycle.com.
kiwi_outdoors likes this.
Motorcycle.com is offline
post #2 of 5 Old 09-02-2016, 02:57 PM
Dear me
That's some ugly looking oil. Can't tell if it is just foamed up with air, or got some coolant mixed in with it. Either way, probably shouldn't be cloudy.
Brojon likes this.
Jimding is offline
post #3 of 5 Old 09-03-2016, 12:17 AM
Check the oil the same way you set a volt meter to test a circuit, CORRECTLY!
notacop is online now
post #4 of 5 Old 09-04-2016, 08:06 PM
billteugene's Avatar
I made fun of my wife's Ducati sight glass for years, because you can't check the oil by yourself. She always said that, Ducatis being Italian bikes, it's a moot point--Italians are never by themselves.
And now I've got a sight glass on my Vee2. Sigh. First farkle was a center stand.
billteugene is offline
post #5 of 5 Old 09-04-2016, 08:52 PM
When checking on a center stand, be aware the full line effectively changes to just below the top of the window. If that's all you got the stand for, this would have been cheaper.
