Replacing an engine for my 2006 650 DL - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 13 Old 08-30-2016, 09:28 PM Thread Starter
I just damage my engine last week riding in Icelandic highlands. It had only a 27.000 km on it and I am told it's very expensive to repair and I should try to find a used motor. Unfortunately I am not the engine expert so therefore I am scratching my head over couple of things:
What year of engine should I be looking for, could I for example use an engine from much later models? Could I even replace my 650 DL with a 1000 engine?
Maybe the most important question, where should I be looking for a used engine?
If you can in anyway assist a guy how doesn't know that much about engines but is eager to get back on the bike it would be much appreciated.
Cheers,
Saevar Gudmundsson
Iceland
Saevar is offline
post #2 of 13 Old 08-30-2016, 09:44 PM
wingnut11's Avatar
Any 650 engine from the first gen (up to and including 2011) will work. If you want 1000 it's probably best to just go buy one, not worth the hassle since you'd essentially have to change the wiring harness with it. Where to find an engine? Ebay, cragslist, the for sale threads here and at advrider. But I'd like to know what's broken in your current engine?
wingnut11 is offline
post #3 of 13 Old 08-30-2016, 09:51 PM
The simplest replacement would be with a 2004-2006 model. Go to 2007 and beyond and for full use you'll either need all the ancillary stuff like the throttle body, wiring harness and a number of things that connect to the wiring harness. I suppose you could use the short block from a later engine if you plug the second spark plug port and use all the old electrics from your present bike, but I don't have details.
The 1000 would be really difficult and expensive if it could be done at all.
realshelby, Hard miles and tenny80 like this.
post #4 of 13 Old 08-30-2016, 10:47 PM
BCSTROM's Avatar
Get a second opinion is what I would do. good luck.
BCSTROM is offline
post #5 of 13 Old 08-31-2016, 04:36 AM
cyclopathic's Avatar
Check eBay for used engines. It might be cheaper to get a new bike.
I don't think 1000cc would even fit and as greywolf said 2007+ are different.
Not sure what the situation in your country in US it would be easier to get a different bike at that point.
Maybe get crashed with good engine and part it out, but there is really no point brand new ones are very cheap.
Visited provinces:
Visited states:
Big B likes this.
cyclopathic is offline
post #6 of 13 Old 09-01-2016, 04:07 PM
nuke's Avatar
Just back from 2 week in Iceland on 2 rental bikes with a buddy and the wives from Biking Viking (Reykjavik). Loved your country and we will return! Unfortunately Biking Viking only rent BMW's but maybe you should consider a used bike or a used rental. Their rentals are in great condition (the two GS 700's (800 cc engine) we rented were quite similar to the dl650's). I am not sure I would want to spend too much effort on a 10 year old bike with a wrecked engine. Iceland bikes do have low kms compared to north america but some of those roads and river crossings are hard on the bikes.
Lrobby99 likes this.
2012 DL650/EXP (fox orange)
nuke is offline
post #7 of 13 Old 09-01-2016, 08:03 PM
Get another bike IMHO. And you never said what the "damage" was on your engine, you sure it needs replaced?
cyclopathic likes this.
post #8 of 13 Old 09-02-2016, 03:22 AM
If it is a hole in casing it may be patched with JB weld or something
post #9 of 13 Old 09-02-2016, 08:03 AM Thread Starter
I am told the craft-shank is wrecked and probably a lot of other stuff in there. What happened was that the engine was hit by a stone and somehow managed to unscrew the screw where the oil-cooler pipe enters the engine, just enough for the oil to leak out. Around 45 minutes later I heard a strange noise coming from the engine. At the exact same time the oil light appeared and I stopped immediately in middle of nowhere. Waited for a truck for several hours to come pick it up.
Saevar is offline
post #10 of 13 Old 09-02-2016, 09:48 AM
I say make sure the oil cooler line is tight/fixed, and then fill the engine back with oil and see what happens.
Tags
damage , engine , motor , replace
