Is there a fix for this? CalSci windscreen cracking - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By itsak9
post #1 of 10 Old 07-03-2016, 02:48 PM Thread Starter
Had this windscreen about 3 1/2 years. Anything I can do about this split that's creeping?
2011 DL650
Copernicus is offline
post #2 of 10 Old 07-03-2016, 03:05 PM
Drill a very small hole at each of the crack to stop it from going further.
notacop likes this.
itsak9 is offline
post #3 of 10 Old 07-04-2016, 01:01 AM Thread Starter
Small hole all the way through?
2011 DL650
post #4 of 10 Old 07-04-2016, 01:18 AM
Yes. Through-drill with about a 3/16 diameter bit, suggest if you are not experienced with drilling Plexiglass or other thermoplastics to go to the hardware store and get a drill bit for drilling plastic. It will have a sharper point to help drill without further cracking. If you can, practice on some other scrap plastic before doing the real thing. It isn't hard to do, just need to have a little "feel" for it. The purpose of the hole is to help relieve the stress that is causing it to crack. Check the mounting screw that is in the middle of the crack, it may be too tight.
Pirate650
2007 ABS Wee-Strom "The Silver Surfer"
2003 Kawasaki Concours "Mabel, the Flying Kaw"
Pirate650 is offline
post #5 of 10 Old 07-04-2016, 01:29 AM
p38arover's Avatar
I've always used just a 1/16" bit, not a 3/16"
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
1979-2008 - Riding on forever
p38arover is offline
post #6 of 10 Old 07-04-2016, 05:04 AM
Whatever works.
Pirate650
post #7 of 10 Old 07-04-2016, 07:10 AM
strominateacup's Avatar
Its worth trying the hole, but IMHO you've left it a bit too long and it will likely start to crack again from the hole as the stiffness of the screen has been compromised by the length of the crack.
There is a guy in our gliding club who has repaired substantial cracks in acrylic cockpit canopies by grinding the crack to open it up and then filling it with an acrylic glue. After polishing it is almost invisible, but it takes a lot of time and probably years of practice. Good luck!
There are holes in the sky where the rain gets in,
and the holes are very small, that's why rain is thin.
Spike Milligan.
strominateacup is offline
post #8 of 10 Old 07-04-2016, 08:24 PM Thread Starter
Looks like I'm buying a new windscreen soon then.
Thanks everyone.
2011 DL650
post #9 of 10 Old 07-05-2016, 12:40 AM
CalSci
Advises not to tighten the mounting bolts very much as it will lead to cracking. I have a new CalSci for about 1 yr now, and it has developed a crack near the port, just like the old one did. I really like the product and will not change just for this problem.
Wildbill1945 is offline
post #10 of 10 Old 07-05-2016, 09:35 AM
MikeB's Avatar
I would do as others have suggested, drill small hole at both ends of the crack and use ATV silicone to seal both the drilled holes and as much of the crack as possible. Then -- if the repair is too unsightly for you -- paint the lower portion of the windscreen flat black or whatever color you prefer. You don't look through that portion anyway. I painted half of mine just to get a dark background the for GPS on a shelf. Doesn't help much, but it's something.
2008 DL650A
2016 KTM 390 Duke
- Mark Twain, 1887
MikeB is offline
