Taking The Computer - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 14 Old 06-27-2016, 02:06 PM Thread Starter
Taking The Computer
I'm planning a ride from Texas to Colorado and I really need to take my computer (laptop). Any experience with how a hard drive handles the bumps? The plans it to put it in the computer bag, then in either a pannier or the topbox. I could strap it to my back via backpack, but I'd rather not do that.
Harlan Dyer is offline
post #2 of 14 Old 06-27-2016, 02:15 PM
NyMeTsFaN912's Avatar
Obviously put the computer in a padded sleeve or figure a way to keep it shock proof which isn't hard to do. The only thing is not keeping it in a top case for long because of the heat. I would keep it in a backpack if I were you, then you don't have anything to worry about.
-John
NyMeTsFaN912 is offline
post #3 of 14 Old 06-27-2016, 03:10 PM
NSdave's Avatar
I commute a bit with my laptop bag in one side pannier. no ill effects as of yet
14' DL1000
NSdave is offline
post #4 of 14 Old 06-27-2016, 03:12 PM
Make sure it's turned completely off, not just sleeping. Hibernating should be fine. If it's a newer laptop with a SSD you really have nothing to worry about.
V-Tom likes this.
eelriver is offline
post #5 of 14 Old 06-28-2016, 10:13 AM
Vdubfreak67's Avatar
I thought new laptops were all solid state hard drives. I know apples are.
Vdubfreak67 is offline
post #6 of 14 Old 06-28-2016, 01:04 PM
Stalky Tracker's Avatar
When I commuted and/or traveled for business, I always carried my laptop in backpack designed for computers. When traveling on the motorcycle I used a padded case and just put in one of the side cases and packed around it. Always made sure it was actually turned off, as that parks the disk drive heads on HDD. I now use a tablet, but really would like one of the new Surface Pros or Book. Never had an issue with how I carried either the laptop or tablet.
YMMV
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #7 of 14 Old 06-30-2016, 12:32 AM
booghotfoot's Avatar
No so. Most tablets use ssd. So do many ultra slim laptops. But SSD is an added expense not usually found on entry to mid price laptops
Sent from my LGUS991 using Tapatalk
There are 10 kinds of people: those who understand binary and those who don't.
New Rider May 2016
K9 Wee
booghotfoot is offline
post #8 of 14 Old 06-30-2016, 01:31 AM
OydnaR's Avatar
I have a Pelican 1495 CC#1 case for my 17" laptop, they make cases for smaller laptops as well
I paid about $125. iirc, I got mine on amazon
I've been contemplating fabricating a quick release bracket to mount as a top case, but in the meantime, I have had it bungeed to my luggage rack for thousands of miles including washboard gravel roads and sub freezing winter frost heaved roads
OydnaR is offline
post #9 of 14 Old 06-30-2016, 04:21 AM
Hard disks that are designed for laptops are designed for these types of circumstances. Obviously when they're in use, the read/write heads are just micrometers above the spinning platters and any light bump will cause the heads to contact the platters. Which means instant ruin.
Some high-end laptops and/or hard disks have G-sensors that will sense a sudden change in G-forces. Regardless of what the hard disk is doing at that time, they will force the heads to move to the "park" position instantaneously if the thresholds are exceeded. This will save your heads and platters in case of, for instance, a fall.
However, when the hard disk is spun down the heads are "parked" in a safe location away from the platters. In this position, they can easily survive the biggest jolts - even jolts that would destroy the laptop itself, such as dropping the whole laptop on a concrete surface. Which is a lot more than what your laptop is going to endure on the motorcycle thanks to suspension and a padded case/bag.
Hard disks are routinely spun down. In fact laptop hard disks are designed with many tens of thousands of spin down/spin up cycles in mind. If you have not messed around with your power saver settings, a spin down will typically happen:
- When you shutdown, hibernate or sleep your laptop.
- When you close the lid even if this doesn't cause a hibernate or sleep
- When the laptop is not in use for more than 5 or 10 minutes and running on battery power
- When the laptop is not in use for more than 30 minutes and running on AC power.
To be sure, check your Power Saver settings and adjust if required.
Obviously if you have a laptop with SSD you have even less to worry about. SSD is now standard in high-end laptops. Low-end or older laptops can typically be upgraded to SSD and I highly recommend you do so. Your laptop will boot up a lot faster and in general will feel much more responsive especially for disk-intensive operations.
benson3vt likes this.
BackPacker is offline
post #10 of 14 Old 06-30-2016, 08:13 AM
aka Rick in Alabama
basketcase's Avatar
I have a small padded satchel that I bought at Office Depot just for these purposes. The bag fit perfectly in the top case of my BMW R1100RT. I've been all over the southeast on week long trips and the typical road surfaces without doing damage.
Now the same bag works as well in the left OEM sidecase of the DL. Given that it is sharing the space with other stuff I do pack so no hard items are wedged against the laptop bag.
So just shut it down, secure it, and then go. No problem.
:thumbsup:
Current ride: 2001 GL1800; Gone away: 5 BMW's, 4 Honda's, 3 Suzuki's
"The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." -Marcus Aurelius
basketcase is offline
