How do you get the rubber piece on the luggage rack? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 13 Old 06-24-2016, 11:25 PM Thread Starter
The rubber piece that is on top of the grab rail/luggage rack. I took it off in 06 without damaging it, but can't for the life of me get it back on. Any advice?
No welcome threads please... I've been on the forums for years but I couldn't get on from my cell.
Arachnyd2 is offline
post #2 of 13 Old 06-24-2016, 11:31 PM
Spray the nubs with some WD40, it will pop right in where it needs to go. So......why did you create a new profile, your original causing issues? And go put some miles on that 06, it is just begging to be ridden. 😉
post #3 of 13 Old 06-24-2016, 11:49 PM Thread Starter
Thanks... I'll try that in the morning.
I don't still have the same email address I had when I joined, and my old password wasn't working. I'll reach out to an admin.
post #4 of 13 Old 06-25-2016, 12:40 AM
Originally Posted by Big B View Post
So......why did you create a new profile, your original causing issues? 😉
I to have created a new profile, I was Yesbut....this password security crap...
Toshbar likes this.
Nobut is offline
post #5 of 13 Old 06-25-2016, 12:50 AM
ocoas's Avatar
Use a small amount of liquid dish soap and water to wash off the WD40.
The WD40 will stay slippery for some time till it dissipates and the rubber piece may pop off till then.
ocoas is online now
post #6 of 13 Old 06-25-2016, 01:03 AM
Old Surf Dog's Avatar
Say it ain't no!
2008 DL650 Vstrom
Rollingwithsurfdog.blogspot.com
Old Surf Dog is offline
post #7 of 13 Old 06-25-2016, 09:14 AM Thread Starter
Sprayed with w40... still can't get them on. Pushed my hardest, tried a c clamp, tried pulling from the back until part of the nub tore...
File Type: jpg 1466856817736381238763_1466856845123.jpg (85.2 KB, 31 views)
post #8 of 13 Old 06-25-2016, 09:24 AM Thread Starter
The only way I could get it is by cutting the nubs... I and using lots of wd40. Thanks for the attempts at help . I know this isn't ideal...
post #9 of 13 Old 06-25-2016, 09:26 AM Thread Starter
Picture of cut... seems to be holding
File Type: jpg 14668574975941023762082_1466857514675.jpg (86.6 KB, 29 views)
post #10 of 13 Old 06-27-2016, 11:56 AM
Dino M's Avatar
Petroleum jelly and use a small diameter (around 1/4") dowel or rod to push from the top. The diameter should be able to pass through the hole in the rack. The reason is you need to be able to push the large diameter portion all the way through the rack.
Stalky Tracker likes this.
Dino M is offline
