ADVICE NEEDED...fuel line connection - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 17 Old 06-12-2008, 11:06 PM Thread Starter
GRS1959's Avatar
Send a message via AIM to GRS1959 Send a message via Yahoo to GRS1959
I just dropped in a new air filter and found a problem: The little plastic clip that you squeeze to disconnect the fuel line from the tank is mangled. It's not really holding the fuel line at all.
Is this safe? I'm supposed to be riding down to Big B's tech day & ride on Saturday
I looked on the parts fiche, and it's not even listed. I guess it might be part of the fuel line (19).
I'm pissed off...the bike was at the dealer last week, which means they left it this way. That's on top of chipping the paint on the top edge of the left fairing (they are fixing it during the off season).
- Gary
Be Ashamed to Die Until You Have Won Some Victory for Humanity. ~Horace Mann
Red DL650K6
GRS1959 is offline
post #2 of 17 Old 06-13-2008, 06:43 AM Thread Starter
GRS1959's Avatar
*bump*
Anyone? Is it safe to ride it like this? Where can I get another clip?
- Gary
Red DL650K6
GRS1959 is offline
post #3 of 17 Old 06-13-2008, 07:29 AM
SCraig's Avatar
The fuel pump should have about 43 psi of pressure. I wouldn't ride it unless I was certain that hose wasn't coming off. You might be able to secure it temporarily with a small radiator-hose type clamp, but personally I don't think I'd try it.
I suspect the only place you'll find a connector like that is at the dealer.
Scott Craig - Nashville, TN
SCraig is offline
post #4 of 17 Old 06-13-2008, 07:37 AM Thread Starter
GRS1959's Avatar
Thanks for the reply, Scott. I was afraid of that. I've had it up to *here* with this dealer.
- Gary
Red DL650K6
GRS1959 is offline
post #5 of 17 Old 06-13-2008, 08:35 AM
SCraig's Avatar
There are good dealers and there are bad. Unfortunately the former are few and far between. I'm lucky in that the place that does my service is top notch.
Your fuel line "Might" be OK. After all, it could have been that way for a while. To be honest I just don't know and I don't think it's worth the risk of it coming loose. As I said, I "Personally" wouldn't ride it until it's fixed properly.
SCraig is offline
post #6 of 17 Old 06-13-2008, 08:50 AM
FireDog45's Avatar
Put me in the not riding until it's fixed column, I don't think the risk is worth it. Even though it may have been like this for a while, it's bound to fail cause you're now aware of it.
Good luck!
Steve
09 GSA
Gone but not forgotten:
Blue 2002 Vee
08 KLR
02 ST1100
99 DR350
FireDog45 is offline
post #7 of 17 Old 06-13-2008, 10:34 AM
MZBuckeye's Avatar
Me too, I wouldn't risk it personally. If it failed totally, there'd really be no way to rig it.
1997 Kawasaki ZG1000 Concours, [COLOR="DarkGreen"]GREEN[/COLOR]
Old bikes:
2001 Kawasaki ZRX1200R, [COLOR="Lime"]GREEN[/COLOR], sold
2005 HD FXDCI, sold
2003 Yamaha FZ1, "Bee", sold
2005 Suzuki DL1000, Black, sold
2002 Yamaha FZ1, Silver, sold
1991 Kawasaki Ninja ZX-6D, sold
1982 Honda Sabre 750 V45, sold
MZBuckeye is offline
post #8 of 17 Old 06-13-2008, 10:42 AM Thread Starter
GRS1959's Avatar
ok... I fixed it.
It seems obvious that the mechanic left the clip on the fuel pump fitting and jammed the fuel line over it. It was definitely not on there correctly...I pulled the line off without having to release the clip at all. It was just a matter of time before it popped off.
The clip should be installed in the end of the fuel line in the correct position, then you push the fuel line onto the fitting until it 'clicks' into place. If an idiot like me can figure out how it's supposed to work, you would think that a trained mechanic could.
I took the clip and gently bent it back to it's original shape and it worked fine.
notacop, Gert and RobertBarr like this.
- Gary
Red DL650K6
GRS1959 is offline
post #9 of 17 Old 06-13-2008, 10:45 AM
MZBuckeye's Avatar
Oh good! Yeah that's the right way to do it. Good for you for figuring it out.
Old bikes:
2005 HD FXDCI, sold
post #10 of 17 Old 06-13-2008, 05:23 PM
FireDog45's Avatar
Good on ya! See you Sat!
Ride safe.
Steve
09 GSA
Blue 2002 Vee
08 KLR
02 ST1100
99 DR350
