Cant get into my OEM Side Case - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 05-25-2008, 06:41 PM Thread Starter
Early today I went to open my side case and the lock just turned and I pulled it out of the case completely. Haven't looked into it much but how do I get into it now or when this happens again.
06 DL1000 Black/ Silver (gone)
09 DRZ400SM
teknoclash is offline
post #2 of 5 Old 05-26-2008, 01:12 PM Thread Starter
Im the only one this has happened too :rolleyes:
09 DRZ400SM
post #3 of 5 Old 05-26-2008, 01:16 PM
VtSTROM-K5's Avatar
Send a message via Yahoo to VtSTROM-K5
teknoclash, the Cylinder engages a "dog" of some type you SHOULD be able to turn it with a flat tip screwdriver if you can see the inset area or with a small pair of needle nose pliers if its a raised tab...............:rolleyes:
2014 V2 DL 1000 25 miles and Onward
IF I only Rode in Good weather..
I WOULDN'T get to Ride in Vermont.at ALL!
we have 2 types of roads in Vermont, Unpaved roads and decaying back to .............Unpaved roads..
2005 DL1000 98,547 miles and continuing in the hands of it's new owner
VtSTROM-K5 is offline
post #4 of 5 Old 05-26-2008, 01:28 PM Thread Starter
I'll give that a try. I know there is a nut that holds the lock in place that has vibrated of. I checked the one on the top case a week ago but didn't get around to the side case's. Should have checked it.
09 DRZ400SM
post #5 of 5 Old 05-27-2008, 07:19 AM Thread Starter
Conclusion
VtSTROM-K5 you were close. There is a plastic lever (dog) connected to the cylinder that is held on by a nut and crush washer. I had to use the short bent end of a allen wrench to push the arm that locks the lid and keeps it closed. Put it back together and checked the other two boxes so that doesn't happen again soon.
09 DRZ400SM
