HELP! Trying to change front sprocket right now... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 05-25-2008, 11:30 AM Thread Starter
This probably should go in the maintenance or mod forums, but I have an emergency and need an answer. I'm changing out my Wee countersrocket to 16t and I can't get past the lock washer.
Its bent so tight up against the nut that I can't pry it away from it. Will this stop me dead in my tracks or would I still be able to get the nut off with a 32mm socket and a 24" breaker bar?
JBStrom is offline
post #2 of 6 Old 05-25-2008, 11:48 AM
I rock at logic
LucasD's Avatar
If you have a wood chisel, it may be time to sacrifice it for the sake of getting that washer bent back. Go buy a cheap one if you don't have one. It'll be able to slide under the washer if you tap it in gently with a hammer, and then you can use a screwdriver once the washer has been pried up.
2006 DL650
"We've done four already, but now we're steady and then they went one, two, three, four..."
LucasD is offline
post #3 of 6 Old 05-25-2008, 11:59 AM
Highveelocity's Avatar
+1. Thats what I had to do
'05 Silver Wee, Givi crash bars, Scotts dampener, JC top box, Battlewings, Homemade fork brace, GSXR calipers with homemade brackets. TCI Outback luggage System, Mr. Eds Moto custom seat
http://s288.photobucket.com/albums/l...ty/56%20Chevy/
Life, repression, and the pursuit of tax money
Highveelocity is offline
post #4 of 6 Old 05-25-2008, 12:34 PM
jackpiner57's Avatar
+1 just pry it away and then use a drift to gently hammer it flat. Use an impact gun with plenty of power or air pressure to remove it easily.
"Build a man a fire and he'll be warm for the night. Set a man on fire and he'll be warm for the rest of his life." - Confuseus
jackpiner57 is offline
post #5 of 6 Old 05-25-2008, 02:13 PM Thread Starter
GOT IT! Thanks. I had a 1/2" chisel that I used - I had to wedge the chisel between the lip of the washer and the nut then hammered gently to get it up. For me that was the hardest part - a 24" breaker bar and 32mm socket from Autozone did the trick on the nut... just a little force counterclockwise with the wife braking the bike did the trick. I was expecting much more of a fight.
Anyway, after three hours and a test ride I now have a 16 tooth sprocket on. Now I'm worried that I didn't get the nut back on tight enough. I put blue loctite on it and used the breaker bar to get it back on snugly while the wife sat on the bike and held the brakes. But then I just realized that I did this with the rear axle loosened for the chain slack! Hope I got enough torque on that thing - I guess I'd better take the sprocket cover off later and make sure everything is okay.
I like the sprocket. I do an indicated 80 (probably about 74mph) right at about 5500rpm. In fourth gear it seems that the tach rpm number matches the speed I'm going - corrected of course, not indicated. I did notice a little loss in that extra snap when I give it hell, but I wanted to relax my riding style and get some gas mileage since I do a lot of interstate. The bike begged to be ridden hard with that 15 tooth... so I did!
JBStrom is offline
post #6 of 6 Old 05-25-2008, 10:09 PM
Roaddane's Avatar
I'll be doing the 16T swap this week, thanks for the tips guys.:hat:
[B]Paul[/B]
[COLOR="Red"]2006 DL650 "Alien"[/COLOR]
[COLOR="Navy"]2005 DRZ400S "Optimus"[/COLOR]
[SIZE="1"]2007 TTR125L (wife)
2007 TTR90 (son)
2009 PW50 (daughter)[/SIZE]
Roaddane is offline
