V-Strom turn signals suck - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 05-22-2008, 02:42 PM Thread Starter
jim.randall's Avatar
Since I've had my V-Strom I thought the turn signals were poor compared to other bikes. My wife even commented that they're hard to see. Inside the enclosure is a standard 1156 bulb just like most other DOT-approved signals so what's up with that?
A little sleuthing reveals that it's because the turn signal housing is miniature black hole. Pitch black plastic - no reflector of any sort. So for nearly nothing, I made some crude reflectors from an aluminum pie pan. The difference is pretty amazing. Yeah, it would be better if they were parabolic but hey, beggars can't be choosers. And no, I don't think there's a chance they will short out since the positive wire goes into the back of the insulated bulb socket.
Penny-tech - you bet!
Jim Randall
DL650, SV650, KLR650, DR350S
jim.randall is offline
post #2 of 8 Old 05-22-2008, 03:48 PM
Living the Stereotype
Stromin'Nroman's Avatar
I put white reflective tape in mine.
Stromin'Nroman NC28729, USA
Stromin'Nroman is offline
post #3 of 8 Old 05-22-2008, 04:27 PM
Redbeard's Avatar
Yup - I put some SOLAS tape in mine - works great.
Take care,
Bob S.
DL1000K6 - Gray
Only motorcycle riders understand why dogs ride with their heads out the window.
Redbeard is offline
post #4 of 8 Old 05-22-2008, 04:31 PM
Compared To What?'s Avatar
Shortly after I purchased my then new 046Fiddy I changed the blinker bulbs out for 21Halogen bulbs. . .
Snipped the original wires, made up some connectors for the pins on the back of the bulbs and slipped them in the housings.
Big improvement over the stock POS bulbs sans reflectors.
Initially I was worried about vibration and heat but in 4 years I haven't lost a single bulb (even when a fast moving truck blew my bike off the stand last year) to vibration and I haven't seen any signs of heat being a problem.
Compared To What? is offline
post #5 of 8 Old 05-23-2008, 01:16 AM
I took the easy way out and installed 50 watt halogen bulbs.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #6 of 8 Old 05-23-2008, 06:11 AM
quema's Avatar
Wow, you guys make my 5 minute tin-foil job look retarted...
But the tin-foil did work wonders as far as brightness...
And I don't think there is an easier / cheaper way.
And Hawaii!
quema is offline
post #7 of 8 Old 05-23-2008, 08:18 AM
Tollster's Avatar
I used egg carton with crumpled tin foil
Tollster is offline
post #8 of 8 Old 05-23-2008, 10:31 AM
MikeB's Avatar
I used aluminized pipe wrap. Anything shiny or reflective will do.
MikeB is offline
