Stripped rear caliper Bolt - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 05-21-2008, 01:25 PM Thread Starter
zed88's Avatar
Send a message via AIM to zed88
Bolt #5 (see diagram below) stripped out when cleaning the calipers the other day. I am going to have a shop take a look and see if they can helicoil it or something similar. Does anybody know the size of the bolt/thread size? Thanks!
dl650k5 -fully farkled- 65k miles. Sold but not forgotten
2006 fjr -roadrunner
zed88 is offline
post #2 of 10 Old 05-21-2008, 01:32 PM
you must mean the caliper is stripped, not the bolt. bummer. looks like kind of a tight fit for a helicoil. you might have to replace the caliper. if i were you i'd start hunting on e-bay.
TouringDude is offline
post #3 of 10 Old 05-21-2008, 01:54 PM Thread Starter
zed88's Avatar
Yep I meant the caliper. I've got a new caliper assembly on order for $110 bucks. I was just hoping the shop could helicoil it so I could go on a holiday weekend ride. I think it makes me more grouchy that I will have to drive the car for 2 weeks than the caliper cost.
zed88 is offline
post #4 of 10 Old 05-21-2008, 02:21 PM
Colin's Avatar
If you take the bolt to the shop they can figure out what size helicoil is needed. I did a similar oops putting on a valve cover recently. The parts guy just measured the bolt and ordered me the correct helicoil.
If the shop will be doing the helicoil you would have to also bring the caliper of course.
Colin is offline
post #5 of 10 Old 05-21-2008, 07:31 PM Thread Starter
zed88's Avatar
Fixed The local shop ran a tap through it and fixed it up nice for $7. Kudos to them!
zed88 is offline
post #6 of 10 Old 05-21-2008, 11:43 PM
Was it a local shop in GB, is so which one. I need to find good local shop.
Thanks
Mbarb is offline
post #7 of 10 Old 05-21-2008, 11:44 PM Thread Starter
zed88's Avatar
Actual it was a local shop down here in the Chicago suburbs. Sorry I could not be of more help
zed88 is offline
post #8 of 10 Old 05-21-2008, 11:51 PM
larolco's Avatar
Had the same problem on mine. That's a nasty bolt.
Cleaned it out with a tap and it works okay. Mental note not to overtighten next time. That rubber boot makes it difficult to tell if the bolt's threading properly.
DRZ400SK17
larolco is offline
post #9 of 10 Old 05-22-2008, 01:09 AM
Tige's Avatar
Send a message via Yahoo to Tige
Now I don't feel so bad. I had the same problem myself. Ended up running a tap through it also.
That damn rubber boot was the biggest PITA to get it right.
Tige
Tige is offline
post #10 of 10 Old 05-22-2008, 06:30 AM
No problem, figured I had a 50-50 shot . Thanks
Mbarb is offline
