12v sockets - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 05-20-2008, 01:09 AM Thread Starter
superstrom's Avatar
Send a message via MSN to superstrom
12v sockets
hey anyone know the best/cheapest way to go about wiring in some factory-looking 12v car plugs onto the v-strom? ive seen some kits for $30-40 can't remember where.
Thanks
V-Strom, Putting beemers to shame since 2002.
[url]www.noblequest.org[/url]
superstrom is offline
post #2 of 19 Old 05-20-2008, 01:57 AM
silverstrom's Avatar
Thanks
I was at Canadian Tire a few days ago a picked up a portable 12 volt socket ($6). It has 2 good sized alligator clamps that connect to the battery and a short cord connected to a 12 volt socket. I was looking for a way to power my compressor without having to permanently mount a 12 volt socket. It's a quick and simple solution if you only want power occasionally. I suppose you could also wire it to a fuse block and have a more permanent set up.
SS
DL650K7
1985 RZ500
1986 NS400R HRC
1987 RG250
1987 TZR 250
1988 RGV 250
1989 RZ 350 F2
1990 RZ 350 N2
silverstrom is offline
post #3 of 19 Old 05-20-2008, 03:20 AM
TravellingStrom's Avatar
Send a message via Skype™ to TravellingStrom
Thanks
Hi
The best bet is to use a marine grade outlet like this or something equivelant
http://www.partsexpress.com/pe/showd...number=265-274
If it is not waterproof, it is not useful on a bike.
Run some cable to the desired location and install the socket, put an inline waterproof fuse in the positve side of the cable, real close to the battery positive terminal and Bob's your uncle.
That is the easiest and cheapest, it is safe as well. But to do it properly you should think about a fuse block, like the Blue Seas or Fuzeblocks and add a relay. Do a search for these on this forum or VSRI.
Cheers
TravellingStrom
TravellingStrom is offline
post #4 of 19 Old 05-20-2008, 04:42 AM
K1W1's Avatar
Powerlet have a V-Strom kit that includes everything you need if you want to take the easy route.
Click here.
K1W1 is offline
post #5 of 19 Old 05-20-2008, 09:25 AM
Tollster's Avatar
Thanks
Can't ever recall "Best and cheapest" ever really working out well! Its one or the other, but never both.
Tollster is offline
post #6 of 19 Old 05-20-2008, 09:59 AM
Newfoundlander's Avatar
Go to Canadian Tire (or a similar store) and get yourself a waterproof outlet and an inline fuse holder, and wire it to the battery...
2008 Yamaha FZ1
2009 Kawasaki KLX450R
Newfoundlander is offline
post #7 of 19 Old 05-20-2008, 12:14 PM
I did a bunch of electricals on the cheap, check this out
https://stromtrooper.com/showthread.php?t=19518
crazyrussian is offline
post #8 of 19 Old 05-20-2008, 01:36 PM
I started with a socket that I got from wal-mart for like 7 bucks, and wired it to the OEM heated grip plug that sits behind the radiator. Since then, I got the same fuseblock as crazy got, and hooked up another outlet, and a stebel air horn. Here are some crappy pics I snapped off during my lunch break with the camera on my phone.
melvin2345 is offline
post #9 of 19 Old 05-20-2008, 02:58 PM
MeefZah's Avatar
My Strom one is mounted to one of the cable clips on the handlebars using a longer bolt and a large nut as a spacer, and a 1" metal wire loom as a bracket. I used a $7 NAPA lighter which is not sold as waterproof but has been waterproof.
Close up, with cap on:
Farther back, cap off:
My KLX uses the same lighter (different cap, I lost the other one), but is mounted to the crossbar using a 1" metal wire loom and a 1/2" metal wire loom:
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You canít grasp its vastness from a plane. Itís diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
MeefZah is offline
post #10 of 19 Old 05-20-2008, 03:16 PM
rhbell's Avatar
I have theCanadian Tire Waterproof cap and works fine for two years now. Also carry the "Bell" socket with the alligator clips, very versatile for any number of things. One thing I learned along the way is that I put a light coating of dialectric grease on the inside of the socket every couple of years -very light coating and it stops the corrosion that occurs in high humidity / rain with these units (I have same on my Lund as well)
My two cents'
Bob
Necessity may be the mother of invention, but desperation is it's father........... (Bell)
'06 DL650
rhbell is offline
