use of piaa lights on the wee - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 05-19-2008, 10:37 PM Thread Starter
will the alternator on the wee put out enough juice to safely power a pair of piaa 510 driving lights @ 55 watts each?
esim68 is offline
post #2 of 3 Old 05-19-2008, 11:01 PM
You have somewhere around 120 peak watts available (less if it's an ABS), so you'll be sucking up almost all of the excess juice.
twowheelnut is offline
post #3 of 3 Old 05-20-2008, 04:38 PM
What Kinda Bike Is That?
Black Lab's Avatar
If you want to use the 510 PIAA lights, go with a 35 watt bulb. That is what I have on my DL-650. I also have Symtec heaters, and a GPS. With everything running, (PIAA lights on, grip heaters on, GPS recharging, and headlight on "high"), my voltmeter will show 13.8 to 13.9 @ 5,000 rpms. If I drop in speed, the volts will also drop to around 12.8. It is rare that I have everything on "full blast" though. Usually, my voltmeter will show 13.9 to 14.1 under what I consider normal riding conditions for me.
Black Lab is offline
