The Big Oil Thread!!!! The Only Oil Thread!!!! - Page 255 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1836Likes
post #2541 of 2632 Old 04-09-2019, 08:09 PM
stevet's Avatar
Those photos-
Lucas, "Meets or exceeds..."
Castrol #1, "Exceeds industry specifications..."
Castrol #2, "Exceeds industry specifications..."
Mobil 1, "Meets or exceeds requirements of..."
And not a single JASO MA certification mark among them. So, it is just their unsubstantiated claim that these products "meet or exceed" those standards. And again, since API no longer certifies motorcycle oils, and that the former API motorcycle standards are now obsolete, you'll likely not see an API donut on a dedicated motorcycle oil. The JASO mark is about all we can hope for.
Keep in mind the corporate lawyers waiting in the wings at the motorcycle manufacturers just waiting to say that your oil related property loss was due to using non-certified oil. It could happen, never say never.
I have seen dedicated JASO certified motorcycle oils on the shelves of good quality MC dealers and parts/accessory shops. Some of those oils tend to be very expensive as well.
I just recently got rid of a nearly empty bottle of Yamalube 20/50 I used with my old FJR, and I'm quite certain it wore the Jaso MA mark. I'd bet the 3rd party suppliers filling the Big 4 MC brand oil bottles are putting JASO certified oil in those bottles, since the MC manufacturers tell us to use JASO oil in their engines.
Steve.
stevet is offline
post #2542 of 2632 Old 04-09-2019, 08:19 PM
STCorndog's Avatar
Originally Posted by Big B View Post
Yet MANY for years and years have been running 40 weight car oil in their bikes with no issues......go figure. I say poo poo on the "official" ratings and standards, if it works it works.
The reason behind this is 40w and higher will NOT have friction modifiers. These were added for fuel economy in 30w and below and can/will cause clutch slippage in some wet clutches.
My mantra is if 40w and higher probably OK. I only use Mobil 1 Motorcycle Synthetics. If Yamaha fights a claim I will let them and Mobil 1 sort it out.
FYI, MA was superceded by MA 2 due to catalytic converters. If your bike has a CAT, I would use MA 2 oils.
STCorndog is offline
post #2543 of 2632 Old 04-09-2019, 09:57 PM
Coach23101's Avatar
Location: Seattle in the summer and East Cape, Baja in the winter. Perfect!
I use Rotella exclusively in my Yanmar 4LHA-STP turbo diesel in a Shamrock offshore Tuna and Marlin hunting machine. It sucks up the normal diesel contaminants. Why the truckers swear by it.
Unless Rotella has broken out of their core market it is diesel oil supremo. And nothing else.
School me if I am wrong. I live to learn....
Coach23101 is offline
post #2544 of 2632 Old 04-09-2019, 10:03 PM
Highwayman2016's Avatar
Originally Posted by stevet View Post
Those photos-
Steve.
When I get a chance I will stop at a dealer. Problem is a new shiny bike may catch my eye.
HokiesRWee, Webfors and Vindex1963 like this.
2014 650 Strom
Highwayman2016 is offline
post #2545 of 2632 Old 04-26-2019, 11:22 PM
JustAnotherDude's Avatar
Originally Posted by Highwayman2016 View Post
I will continue the search...
I'll put my faith in observed performance over a paid-for box or donut. Performance as shown by V-Tom and WERA688, both who have put 100's of thousands of miles/kilometers on their bikes using automotive oils. I'm sure there are others who have mileages like that using certified oils. I'm not convinced having paid for the logo means a hill of beans in real-world application. Failures are not an option for these suppliers as word of mouth from users probably has more impact on sales than slick marketing.
V-Tom likes this.
JustAnotherDude is offline
post #2546 of 2632 Old 04-27-2019, 11:13 AM
Iím with you on that. Going by what others have done and having an oil analysis done to confirm oil longevity/breakdown to set my drain interval.
2014 650 Strom
post #2547 of 2632 Old 04-27-2019, 11:24 AM
STCorndog's Avatar
I am a synthetic believer. The unbiased test data is out there for all to read.
Until somebody proved we would not sail off the end of the earth, we all that it was flat.
post #2548 of 2632 Old 05-07-2019, 06:20 AM
Webfors's Avatar
Rotella's T6 15w40 is the talk of the town right now over at BITOG. Mostly due to the level of shearing you get with the 5w40 T6. If the 15w40 is more shear stable I'll consider it. I've seen the 5w40 shear to a 20 weight in some bikes.
Two wheels for realz!
Webfors is offline
post #2549 of 2632 Old 05-07-2019, 06:29 AM
Motor7's Avatar
Are we talking Blackstone or equivelent testing? I run the 5w40 T6 in everything I own from Tractors to generators. I run it to 10K in my DL but have not sent it out to test for 5-ish years. So did something change?
'15 DL650XT
Motor7 is offline
post #2550 of 2632 Old 05-07-2019, 06:51 AM
Webfors's Avatar
Correct, there are lots of UOAs (Use Oil Analysis) on BITOG that report the shearing, sometimes as high as 25%. Obviously not a major issue when you look at the experience of users that have gotten loads of miles on this oil. But it's worth mentioning in a wet sump bike. If it is meant to run on a 40 weight, I would prefer to have a 40 weight oil for the duration of the OCI.
I'm currently running Valvoline 20w50 conventional. Shifts like butter. I suspect after 1000 miles it'll shear to a 40 weight.
Webfors is offline
Tags
10-40w , maintenance , mobile 1 , oil , rotella , synthetic
vstroma.com not correct thread ? GT_Hawk DL650 and DL650A - 2004 to 2011 7 06-15-2010 12:29 AM
Protective equipment thread.... gwkennedy General V-Strom Discussion 57 01-21-2009 07:56 AM
