Front fender: ABS plastic? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 05-05-2008, 04:52 PM Thread Starter
Living the Stereotype
Stromin'Nroman's Avatar
Is the front fender really made out of ABS plastic.
I'm planning on re-modifying mine and am considering using ABS pipe glue to attach a "patch" to fill in the thin spot where the tire rubbed.
Has anyone ever tried such foolishness?
Stromin'Nroman NC28729, USA
Stromin'Nroman is offline
post #2 of 7 Old 05-05-2008, 04:57 PM
bobosmite's Avatar
My fenda extenda is attached with ABS pipe glue and it's solid as a rock. I had it off this weekend and it's strong like one single piece of plastic.
2014 Suzuki DL1000
SEARCH is your FRIEND
bobosmite is offline
post #3 of 7 Old 05-05-2008, 05:11 PM
Pull the fender. It should be marked on the underside for recycling purposes.
twowheelnut is offline
post #4 of 7 Old 05-05-2008, 05:38 PM Thread Starter
I does have "ABS" embossed on the underside.
The question arose when I realized I have Anti-Lock Brakes.
Thanks for the info.
post #5 of 7 Old 05-05-2008, 08:31 PM
condensr's Avatar
When I had an old Apache popup camper that had ABS in place of the canvas, I learned a good trick to patch ABS.
You'll need some ABS plastic in the desired color, as well as MEK (Methyl Ethyl Ketone, available at big box hardware stores in the paint section).
Get a glass (IMPORTANT) jar with a lid, and grind up the abs, or shave it in to small pieces. Set this aside. Pour some MEK in the jar, and start adding shavings, stirring to dissolve with a metal or wood rod, until you get a thick 'liquid plastic'. You can now use this to patch ABS, and it will chemically fuse to the ABS surface you are patching and become one piece of plastic.
DL650K6 in Red
1981 GS1000GL
2002 Subaru Outback VDC H6
condensr is offline
post #6 of 7 Old 05-05-2008, 09:14 PM Thread Starter
This is exactly why I became a $tromtrooper.
Thanks a lot.
post #7 of 7 Old 05-05-2008, 09:32 PM
What Kinda Bike Is That?
Black Lab's Avatar
My side cowlings have ABS marked on their insides and I DON'T have ABS brakes...........sort of made the same "huh?", when I realized, ABS plastic.
Black Lab is offline
