SW-MOTECH crash bars: Bolt too long? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 05-04-2008, 02:31 PM Thread Starter
pfbz's Avatar
Just installed SW-Motech engine guards on my DL1000K2. The main through bolt seems quite a bit too long...
Is this typical? And what have people done to rectify it?
I'm thinking of getting my grinder out, cutting it, and chasing the threads with a die.
Any other brilliant solutions?
[CENTER][SIZE=3] [I][FONT="Comic Sans MS"]Dualsportz
[/FONT][/I][/SIZE][size=2][COLOR=yellow] [FONT=Impact]< [color=darkorange] KTM 950 Adventure[/color] | [color=darkorange] KTM 950 Super Enduro[/color] | [COLOR=darkblue]DL1000 VStrom [/COLOR] | [color=darkorange] KTM 450 EXC [/color] | [color=darkorange] KTM 300 XC [/color] >[/FONT][/size][/CENTER] [/COLOR]
pfbz is offline
post #2 of 5 Old 05-04-2008, 04:37 PM
Did you add enough washers to kick out the spacers so the bars don't touch the frame but only the spacers? If so, it's up to you. There is some variation in how many washers are needed. My '05 took two and my '07 only needed one on each side. The bolt is made long enough to fit the worst case scenario. Replacing the bolt with SV-Racing sliders and their double nut and threaded rod entirely contained within the slider was my choice.
post #3 of 5 Old 05-04-2008, 08:38 PM
Ditto what Greywolf said. You don't want the Bars resting on the frame, make sure there is a gap on each side. Mine also used 1 washer on each side.
Kevin
L2 DL650A The Orange Machine
K7 DL650 Hi Yo Silver R.I.P!
khager is offline
post #4 of 5 Old 05-04-2008, 10:38 PM
sledjockey's Avatar
Mine sticks out a little bit on one side even with the spacers, washers, etc. I left it for now, but will end up taking it off with a saw and grinder eventually. It really doesn't get the the way right now, though. It only sticks out about 3/8 - 1/2 inch.
"I will stop the motor of the world."
John Galt
http://ageofdecadence.com
sledjockey is offline
post #5 of 5 Old 05-04-2008, 11:52 PM
MeefZah's Avatar
Mine is slightly long, but not long enough to care about.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You canít grasp its vastness from a plane. Itís diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
MeefZah is offline
