brake pads - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 05-03-2008, 03:05 AM Thread Starter
brake pads
i got some front brake pads with the bike. When I went to install them I noticed that both of them are the same side pads (FA229).
These are EBC Kevlar series. I went to the local dealer to get FA231 (Right side) but he only has FA231HH which is a sintered version:
Question: Can i put FA229 (kevlar) on one side and FA231HH (sintered?) on the other side?
vinpub is offline
post #2 of 12 Old 05-03-2008, 03:48 AM
cavehamster's Avatar
Send a message via AIM to cavehamster
I can't help giggling every time someone uses 'break' instead of 'brake'. I just imagine them going for the 'breaks' and the bike snapping in half or something...
Anyway, how many miles did you get out of the stock pads? Mine look ok, but I have almost 28000 miles on them, and it has had me wondering lately...
cavehamster is offline
post #3 of 12 Old 05-03-2008, 07:43 AM
16171
Brake(or Break) Pads should be of the same material on both sides...I would think at least.
I'd not mix materials....
I'm just sayin...
BTD.
post #4 of 12 Old 05-03-2008, 08:35 AM Thread Starter
Thanks a bunch for catching the mistake. I guess I am not much of a speller - I am used to just let old Bill Gates check my typing everytime, usually he is a lot more attentive than I am at late nights. But even he wouldn't catch something as tricky as this!
I have ~24K on them. They may go for another 3-5K in the front but I needed to get the rear pads replaced anyway, so i was going to do the front ones too while i was at it. That's when I realized the left and the right sides are different.
vinpub is offline
post #5 of 12 Old 05-03-2008, 01:23 PM
Send a message via AIM to coop74 Send a message via Yahoo to coop74
mixed pads
Don't mix pads. I don't have a reason other then it would seem they would/might wear at a different rate and grab differently which i would think could apply slightly different torque to either side of the wheel.
Again I don't think it would be wise.
Coop
Robert "Coop" Cooper
03 DL1k
00 KLR650
Alcoa, TN
coop74 is offline
post #6 of 12 Old 05-03-2008, 01:37 PM
Mr.Metal's Avatar
Coop
+1
Different brake pad materials have different initial bite and different gripping properties as they heat up. I would also tend to think that mixing them might result in weird behavior and definitely uneven wear. I'm obviously not an expert, but I'd stick to the same material if I was faced with that situation.
2008 DL650 a.k.a. Road Warrior, member #16 of the Flat Black Club
2009 Aprilia Tuono 1000R a.k.a. Silver Thunder
Mr.Metal is offline
post #7 of 12 Old 05-03-2008, 02:31 PM
+1 Mr. Metal.
Besides it may pull to one side due to on side gripping better then the other side.
2003 V - ASV C5 Levers, Univ. Solex bars, grip heaters, ktm mirrors, c.stand, SW Mo Engine grds,Two Bros, PC3, Garmin, Givi 460, tank bag, F. Extenda, BackOff, Super Brace, Elka Shock, Race Tech Gold. AWD/Mr.Ed's Moto seat mod. Dumonde Tech Racing Oil, Spider grips, Contour.
2001 KTM LC4 farkled (sold)
awd505 is offline
post #8 of 12 Old 05-04-2008, 02:51 AM Thread Starter
Thanks you all. I didnt think of the difference in the reposne of the diff material. Thank you for pointing that out.
I'll just wait and get kevlar pads instead of sintered ones.
thank you.
vinpub is offline
post #9 of 12 Old 05-04-2008, 09:27 AM
Send a message via Yahoo to Prykar
Originally Posted by awd505 View Post
+1 Mr. Metal.
I don't get this one. Why would it pull to one side? It's one wheel.
Please explain.
Prykar is offline
post #10 of 12 Old 05-04-2008, 10:05 AM
Hmmmmm
ladukebob's Avatar
+1 Mr. Metal.
I don't really think it's going to "pull" to one side. Worst thing that's going to happen by using two different pads is one side of the rotor wearing differently the other.
"there's no fighting in here, this is the WAR ROOM!"
2015 ktm 690r The Divide, been there done that
Past bikes-
05 dl 650
07 dl 650
ktm 990
ladukebob is offline
